I did a quick read over you ride report. Doesnt look like you had a bone stock 0 mile 850 in the group.
What is the point of the test if you didnt have the factory engine right next to you getting the same abuse?
You are correct i did not..... and however i would have like to but it doesn't matter at all for what i was testing.
I did....( is what i believe to be a change the motor has to have to be really dependable ) The only change i made that requires testing was the grooves i machined into the center crankcase cavity around the center seasl..., and the cylinder honing.
As far as the....
lock ring groove ( motor just needs this )
shorten rod oil fittings ( long fittings was a stupid move ) the 900 had them.
Stock head volume ( different shape ) done this many times.
I will pull this motor down after the next 3 trips and post pictures of the pistons..... by that time will have lots and lots of stock pistons to compare to.
I will aslo leak down test the motor after each trip.
My instints tell me no premix is stupid.... but i did it to maximize the torcher to the piston coating..... Mark my word by the end of the season the pistons in this motor will look amazing compared to any OEM honed cylinder by a long long ways.
And the leak down will be better.
Dan
