WARRANTY
OH MY ! This got way off track as far as what I was frustrated about. SORRY !
WHAT GoBigParts “ sparked “ was more about the same on the PTO bearing ( As TRS Tony says........ ) it’s a blind hole case...... And it’s not like each 1/2 of the bearing bores are machined separately.
They are bored when they bolted together ...... Because of the length ....It’s most likely bored with a boring head so steps are not an option.
So..... that is why I said from the beginning it needs a bearing lock ring..... ( either way ) it is a completely different tool used to cut a groove.
It’s a floating bearing so it really can’t be trapped in the case boring process.. it needs a pin or lock r8ng.
My frustration was really pointed at the center bearings ( like mentioned in another thread ) where 2 motors went down because of the center bearings.
If Polaris thinks there is a ( proper fix to the Bottom-End ) with it in a Assemble state they are dreaming.
Indy Specialty LLC ....... and all of you people are 850 customers.
The sled has a 4 year warranty........ and it needs to be fixed correctly.
And my stance stands the same as from the beginning.... The motor needs a full blowen recall be done correctly.
The bottom-end PTO bearing has to have.....A Locator
And the Bottom-end center oil cavity has to have.... a better over-flow.
It’s funny to me...... Polaris can’t seem to except the facts yet....and they are not set up logistically to ..... ( Fix mistakes ) they are only capable of NEW from a mass production stand point.
And what’s really funny...... Is that a Red Neck company like Indy Specialty could pretty easily handle fixing say 10,000 motors fairly fast.
But it would ruin the business because all normal customer work would have to stop completely..... and that would create a hole that would be very costly to refill...... so no outside company can do the job unless Polaris owns or buys them.
The warranty turn around would ruin a secondary company after it was over ( because of the losss of flowing business to what they did from day to day. )
So my guess is this...... Not Polaris, and Not any other outside secondary company can solve this problem until ( Spring ) and summer on a full recall.
The Logistics are staggering......
it would also kill most Polaris dealers....... ( BECAUSE ) and I am going to say this next statement loudly.
POLARIS DOESN’T PAY THEIR DEALERS **** ON WARRANTY WORK !!!!
NOT ONLY DO THEY NOT PAY ENOUGH HOURS REQUIRED TO GET THE JOB IT SELF DONE.......
THEY DO NOT PAY FULL SHOP RATE...... ITS A DISCOUNT INTERNAL RATE THAT BARELY COVERS THE TECHS WAGES !!!
AND NOW THE TECHS ARE ALL TO BUSY FIXING POLAIRS SCREW UPS TO MAKE FULL SHOP RATE ON GOOD CUSTOMER WORK YOU HAVE.
I AM GOING TO MAKE 2 MORE AGGRESSIVE STATEMENTS POINTED AT TWO COMPANIES...... ONE BIG AND ONE SMALL.
#1 - POLARIS INDUSTRIES
#2 - HANSON RACING
I BELIEVE FOR THE FIRST TIME ITS POSSIBLE FOR ALL,DEALERS TO STAND TOGETHER UNITED AS A TEAM AND DEMAND FULL SHOP RETAIL ON ALL 850 WARRANTY WORK .....
FOR EVERY HOUR & EVERY MINUTE ....AND ALL LOGISTICAL BULLCHIT ( MEANING.......
PHONE CALLS WITH CUSTOMERS
LOADING AND UNLOADING SLEDS
DIGGING SLEDS OUT OF THE SNOW
THAWING THEM OUT
DEALING WITH WARRANTY BS
LOSS OF OTHER BUSINESS ( in other words screwing up your entire business because os Polaris )
DEALERS PLEASE HERE ME ! ......( DO NOT LET THIS TURN INTO A 900 FUSION OR 800 DRAGON DEAL )
THE ENTIRE DEALER NETWOEK SUFFERS FROM THIS FAR WORSE THEN POLARIS........ ( DEALERS MUST UNITE NOW )
NOW TO ( ERIC ) @ HANSON RACING ENGINES - ERIC I WOULD FIRST LIKE TO SAY I AM VERY SORRY ABOUT THE PASSING OF KEVIN SEVERAL YEARS AGO.
AND I COULD ONLY WISH HE WAS BY YOUR SIDE TODAY !
I CAN ONLY BET THAT POLARIS HAS COME KNOCKING AT YOUR DOOR WITH THE 850 TRAIN WRECK.
I WISH YOU POWER AND THE BALLS TO STAND STRONG AND REALIZE THAT THIS WILL ONLY BE GOOD FOR YOU ( HANSON RACING ENGINES ) IF YOU THINK OF YOU AND YOU ONLY.
I SUGGEST YOU GET A GOOD LAWYER OR BUSINESS ADVISOR TO HELP YOU WITH A TRUE AND SURE PATH TO MASS PROFIT OFF THIS POLARIS BLUNDER.
AND DON’T THINK FOR ONE SECOND THAT YOU ARE LUCKY BECAUSE THEY CALLED !
YOU CREATE YOUR OWN LUCK TO SOME DEGREE !
SO STAND STRONG GET PAID AT LEAST 1/2 THE MONEY UP FRONT.
TAKE WHAT EVER PRICE YOU THINK YOU NEED TO CHARGE AND TRIPPLE IT.
AND MARK MY WORD MY FRIEND .....ERIC IN THE END YOU WILL SAY THE FOLLOWING.
IF DAN FROM INDY SPECIALTY HAD NOT POSTED THIS MESSAGE ON SNOWEST I WOULD HAVE GONE BROKE HELPING POLARIS.
AT TRIPPLE THE PRICE YOU THINK YOU CAN DO THIS TYPE MASS WARRANTY WORK AT...... WILL LOGISTICALLY RUN YIU RIGHT OVER AND LEAVE YOU FOR DEAD.
AT TRIPPLE YOUR HIGHEST ESTIMATE YOU WILL STILL BE ON THE SHORT SIDE.
EVERYONE OUTSIDE POLARIS NEEDS TO STAND TOGETHER AND DROP THE HAMMER ON POLARIS THIS TIME AROUND.
ALL, LOYAL POLARIS CUSTOMERS & DEALERS MUST STAND UNITED THIS TIME AROUND.
DAN
Excuse my ignorance.
Machine a space for the bearing in layman's terms.
Currently the case has room for the bearing to slide toward and away from the crank.
If u 'machine a space' for the bearing. It will be just large enough for the bearing. Leaving zero space for the bearing to slide.
U would have a 'lip' on each side of the bearing, essentially holding it in place, similar to ur clip. U will have a set space away from the crank and on the other side , a space away from the seal.
This is not something u can do to the current cases but could with future cases.
#2 - HANSON RACING
THAWING THEM OUT
DAN
