So I was wrong..... At 10.7 hours on my 850 The PTO oil line did not pop off. The oil line that feeds the water pump cavity popped off. I was able to personally inspect the crank bearings and other engine internals at the dealership, and was happy with how the bearings felt and top end looked. Still no difinive answer as to why the cavity built pressure and blew the line off. Dealer tested both entry and exit check valves, and both flowed freely. No evidence of excess sealant inthe cavity.... We do not have Polaris marching orders yet as to how to procede. I will update once a proposed solution arises. EDIT: The waterpump cavity was full of injector oil upon dis assembly according to the dealer.
I believe the biggest mistake Polaris has made on the 850 is sealing up the center section & putting a banjo fitting in the upper case half.... I know they were trying to make the oil level deeper then the bottom of the center bearing mag drain..... and figured it was better to fill the center.
As I believe it wasn’t bad thinking.....but 2 big mistakes were made in doing this.
#1 - switching the center seals from ( inside the bearing ) on the outward side of the center bearing. ( in other words.... a sealed bearing ). To a non-sealed bearing and putting the seal inward of the center bearings.
#2 - using a banjo fitting as the cavity drain in the top.
2 - big dependability risks here....
#1 - the oil pump pumping against a check valve with a tiny hole easily plugged with a gear wear or case sealer.
#2 - center bearings that no longer use center gear cavity oil to lube the center bearings ( center bearing now depend on oil from inside the rod cavity ) around the crank wheel... and with crankshaft wind and centrifugal force makes it really hard for those 2 bearings to get oil.
So what I did might go strongly against an engineers line of thinking...
I put the upper case half in the mill and programmed a set of grooves past both inner crank seals... which some might think creates short circuit to both cylinders destroying the integrity of sealing the cylinders from themselves.
Not the case at all.... as matter of fact what I did is the single biggest fix to extended center bearing life and PTO rod bearing life.
2 examples to think about .
1- a utility trailer with a rear loading ramp made with expanded metal, chicken wire, or lots of slots for the air to past thru.
At high freeway speeds the holes basically almost completely go away.... if you think I am kindling.... go on a 200 mile trip at 75 mph with a V6 SUV and check your mileage..... then take the ramp off and try it.
2 - the center is ( Full ) of oil and it has hydro lock protection.
So it doesn’t mater if you tie them together..... as a matter a fact there is no down side.... it’s all plus’s. ( granted they have to be the correct size )
The groves are at the very top... and they create a positive drain to both center bearings and both cylinders ..... ( instead of JUST to the mag cylinder) and no oil to either center bearing.
This small little trick insures the center oilline will never over pressurize and pop off.
Dan
