Some metallurgy on this topic regarding the floating bearing. It is tough to argue Dan's information on this one. When you have a very solid bearing material (hardened carbon steel) which expands at a different rate than the aluminum clamping material with heat, you will absolutely see the dimensions of the aluminum case material expand more than the steel, even if somehow they are kept at the same temperature. Aluminum will expand at a rate of 21-24 (10-6 m/(m K)) versus steel at 11-12.5 (10-6 m/(m K)) given the same temperatures. Even these numbers point to issues with an expansion difference...now throw in the real-world fact that aluminum has a much faster heat transfer, or absorption rate, of this heat (how fast it moves the heat into the material) at 125 (Btu/(hr F ft)) versus steel at around 20 (Btu/(hr F ft)). This is a major challenge in matching these materials when heat is applied fast (which would mean any moving of the sled at all). What this all means is that you have cases that absorb the heat 6x faster and grow 2x more than the steel...that means the "clamping" of the cases on the bearing loses force really fast. Add the hammer affect of the clutch and it is not the most absurd notion to conclude that the bearing could be moved. More material evidence? Aluminum does not bond well to such a dissimilar material...the molecules simply don't align, fit and bond...they move. The galling is from the mismatch of molecules and material tearing/shredding and failure on a microscopic level. We are all too familiar with this with the piston to cylinder interface (which, by the way is fairly closely matched in expansion rates), but it applies to the bearings in a much more significant way. Warm up to me is less about pistons than bearings. And even with perfect warm-up, the bearings to case are a natural weak point. Not having a method to keep them in-place is haphazard for this clutch hammering application. No side load...no biggy...actually helps keep things in place. With a slide load...better have a back-up retainer method...or the ring. Sorry for the nerd-out...but there is a reason these materials walk with respect to each other. The science backs up everything Dan says. As a matter of fact, there is nothing that I see as an argument to his point. And I will call it out in a tactful argument if I disagree. It all makes sense.
