C
CompFusion
Compfusion...ya left me hangin' bud!I posted pics for you...what do YOU see?
Sorry, but I don't get online near as much as I used to. I wish I had the time to spend on here ... Probably sell more mount kits..
Your failure looks typical of the, ahem, few I've seen. Definitely oil related, or lack thereof. The other side shows the blowby and symptoms of cylinders which are neither round, nor straight. I've seen way too many of these right out of the box that need to be resized and fixed. Are any of these engines using the nikasil kit like the new 550 engines?? Effective heat control and evacuation was a big problem with these sleds especially when driven at lower speeds as SuperDave stated. Sleds driven like they were stolen didnt seem to exhibit the problems. The newer nikasil engine addressed the oil issue in several ways. The non-iron lined cylinders transferred heat better to the atmosphere, the CDI module had a different timing curve to change heat generated in the engine, the exhaust had shields attached to not release as much heat into the engine compartment, jetting was changed, and the oil pump had a thermal barrier added between pump and case along with a self bleeding setup that would catch the air and return it to the oil tank each time the bottle was filled.
I do believe that these engines can be made to run trouble free (and many do) with careful setup and maintenance. Don't run too loose a piston clearance. This can cause problems especially in electric reverse engines. .004-.005" is plenty. If the auto-bleed kit is not installed on the oil pump then check and bleed it on a regular basis. An "air catcher" can be made in similar fashion to a water trap on a carburetor. It would consist of a fitting in place of the bleed screw with a short piece of hose extending upwards and a plug in the end. As air is accumulated in the pump it would rise into the hose instead of causing an issue inside the pump and could be released periodically. The auto-bleed does the same thing without user intervention ... probably a good thing anyway..
Try to jet proper and not dump fuel into it. It is generally not the issue and excess fuel only makes the oil situation worsen. If you expect the drivers are driving in the critical range run premix in the tank along with the injection. The ill effects of too much oil are way more long-term than lack of it.
