Anyone have a part # for a x3 center punched?
Sent from my DROID RAZR using Tapatalk 2
On the box that my track came in it says WPS 9220LE
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
How hard it is to remove the chain-case??
Lynn,
Gluing it on is a good idea to minimize the dreaded tunnel side Wrinkle.
Dropped my deposit on a 162" and drivers today!! Jake from Carls Cycle said the 162 is 8-10lbs heavier than stock...
They didn't give an actual weight? Do you know how much the stock 162 is?
PV
Anyone buying the cheaper 9129 and cutting it down? Seems like a viable option cause it also gets your paddles out to the actual edge of the track? Im thinking about going to a x3 of some sort...just cant make up my mind. Stock '13 w/ carls clutching. Thinking a set of drivers and the 9220 would be the ticket.
All track cutting voids the warranty from what Camoplast told me directly.
Plus... how much more traction do you need from a track with that extra 3/8" of track to the edge?
http://www.snowest.com/forum/attachment.php?
attachmentid=213138&d=1380411255
My "guess" on the paddles is so they can use the same form/mold for both track widths, then just cut the belt to width.
There are possibly some upsides to the narrower paddle....less track/tunnel contact and maybe a little more agility without the paddles going all the way to the outside. On the full width paddles there was always quite a bit of rubbing and chunks of outer paddle getting torn....that can't be good for track speed and always raised a red flag when trying to warranty for any reason.
I would like to see an inset of 1/8"-ish...max paddle and still avoid contact.
