2020 850 Issues Thread
So I have a 2020 sba 850. Got about 20 miles on it if that. Noticed there was burnt oil in the belly pan. Took a pic and called the dealer. Said oh it's just the exhaust donut. Didnt seal. I was thinking theres no way a new sled should be leaking oil. So I decided to take it apart and lo and behold. Theres a pin hole in the y pipe coming off the engine. Best part is theres a 3 week wait minimum to get sled in and if they can even get the part yet. Pics are included.
weld the pinhole on the y pipe.
I got my 2020 Khaos 850 broken in this past weekend. Ran pretty good for the first 0-50ish Miles. I felt it doing it’s break in process, so I was very anxious to see what it felt like after break in. Started the next day off pretty strong until about mid day it started to bog a few times on me bad. Checked the plugs of course right away, the one side was golden brown but the other side was soaked in oil. Swapped plugs out for some fresh ones. Ran amazing after than until the later part of the day and I got a few more bogs. Heading home today and will check plugs again. Motors all stock with Indy dans clutch weights. Rpms were spot on.
Probly have to keep pushing through. How many hours above 5500 rpm you think your at? There's extra oil for 10 hours.
Sent from my SM-G960W using Tapatalk
I hope that’s all it is. I ended the weekend with 110 miles on it. 50 to 60 of it burning trail. The rest all off trail. I’m not sure about the amount of hours above 5500rpms.
Incorrect
Probably just oil spray I guess . Quality control ??
Seems like they could get you one sooner as many engines have gone down , by the internet failure rate.
I would say the Swedish one is wrong. That would make zero sense to over fuel it and not oil for the extra 8 hours.
New 2020 RMK 850, last sled was a 2016 RMK 163 800. The 850 throttle pull is very stiff compared to the 800. Is this normal? My 13 proclimb is about the same as the 800.
Other than that...the power is great, starts great, sounds great.
Daemond your dealer sucks. Least he could do is pull the y-pipe, weld/tack that tiny hole shut then have you run it while hes waiting for the part. While you wait in the shop maybe buying more stuff from him.
I'd bet $100 Polaris would not cover welding this under warranty.
First ride yesterday on the 2020 RMK 2.6 and it is DEEEPP. Hard to try and be nice to it when you need a good hand full on down hills but it ran mint. Zero issues so far. 5 more days of 3 feet of POW to go! Can tell its a little rich but still runs very good and clean.
