A
ACMtnCat
Wish I knew if, when and what the fix will be. I have just over 1 mile on mine so I would like to fix mine before that plate gets too chewed. I think the ideal fix is add 2 more adjusters evenly spaced from the original and delrin tip all of them... That should eliminate any wobble in the sheaths while spreading the load so the delrin tips and plate wear slower. Perhaps an interm fix is run a second adjuster in the belt tool hole?
Polish your stock bolt tip and slightly round the edge of the tip while your at it so it can't dig into the plate. Then re-install the outside sheave 180 degrees around so the bolt slides on a new slide area. Run it there and don't worry about it unless it makes a noise you think is super bad. If it's bad take it to your dealer and have them fix it.
If it's not under warranty you may be replacing the clutch soon with one that doesn't grind and squawk.
