All of the 2016 7000's secondary clutches were recalled to be replaced because they were noisy.
My guess it's because the engine is quieter and the clutch noise is more pronounced.
Just take out the deflection adjuster completely, then adjust your deflection by using washer shims between the sheaves.
Done.
Clutch aligners is done by adding washers to the back of the clutch so I don't know how that got miss communicated earlier but it's pretty simple to look and say, Hey if I just add washers between the sheaves I don't need that bolt.
Also I probably never here mine because the belt deflection is tight, my belt is on the verge of squeling, so just as soon as I take off the secondary is engaged and no noise. What a huge problem omg.
If they are recalling clutches that's just idiotic. These clutches are such a massive upgrade from anything before but ppl gotta have something to batch about and screw it up for us.
Hey Artic Cat, here's to you for doing something right, I got your back 100% on this one! Now the panels and boards on the other hand. .....
And gearing![]()
Done.
And gearing![]()
wow - guess I better look over the manual and get up to speed on this new secondary....
Secondly - You do not adjust alignment by shims behind the clutch it is adjusted by the shims in the middle of the clutch!
Sounds weird , anyone confirm this.
Completely WRONG!!!!!! Got your heap up your butt on this one Wyo!
First off - You DO NOT and CAN NOT adjust deflection that way.![]()
Thirdly - There is a problem with the secondary clutch and Arctic Cat is looking into it. We talked to Shawn at Arctic Cat about it and he is working on it and he thought the Derlin tip was a great idea IF IT HOLDS UP!
And here is a update on the derlin tip: It worked AWESOME! Completely eliminated the screech of metal on metal that was happening!More testing this weekend, trying another idea in conjunction with the derlin tip adjuster.
Slide area is near perfect, just starting to rub the hardened steel coloring off.
The tip is polished smooth and showing no sign of wear.
Not hard to see how it works if you just look at it.
The inside sheave moves in and back out. The outside sheave does not move and is aligned by washers / shims against a shoulder on the shaft. REAL SIMPLE!
I went a different route to try to solve it. I machined a brass tip to go in the end of the bolt. Hopefully I will test it this weekend. FYI I used a drill press and chainsaw raker file for the machine work.
I have a 2016 HCR with no miles on it yet. Heading to mountains in Quebec next weekend for a few days. I hope I don't run into this problem or worse.![]()
The ONLY thing adding Shims does..., THE ONLY THING ADDING WASHERS / SHIMS DOES IS ALIGNMENT. The only way you can adjust deflection is with the deflection bolt NOT washers. REALLY REALLY SIMPLE.
