Does ut get any worse if u change fuel plug to 10% eth??
Mine is worse when I am running the 10% ethanol resistor. Non ethanol resistor and the best premium fuel I can find makes it run better but I am still experiencing some bog ever now and then.
Does your sled act like mine ----> http://youtu.be/uv1ZTrg0Qzc
??? If it does maybe we have the same probs.
Yes mine is very similar, mine sled is even an orange assault too. I have a video of mine bogging as well, but because I have a Jaws can it is a little more noticeable in the video just by the sound. I will post the video when I get back to my computer next week.
I rode mine again today and my bog isn't as bad after going over it, but still not gone completely. I am going to have to bring it in I think and have them test the injectors and maybe try a different ECM. My warranty has been up since october so it'll all be out of my pocket now.
Seems to be worse when I put the 10% ethanol resistor so when the sled run richer.
So what can make the engine to bog more when it run richer ??
I also notice that this bog happen more at higher outside temp.
I also try different fuel adjustment with my PCV and the richer I run, the worse it was.
I will install my afr this week so i will be able to check what it happen when the bog occur
did u ever try with the stock can on ?Got my pro back today from the dealer. They tested injectors and tried to replicate my bog and couldn't get it to do it. I plan to ride it this weekend and see if I can make it do it again.
I just installed a rk Tek drop in kit n have roughly 250 miles on it and tonight while in powder at WOT, I hit a slight bog. Got off n on the throttle n not that exact moment but it did eventually bog out again 1/4 mile down the road. Changed plugs n made it another 1/4 mile and it bogged out again.. Got on hard packed trail and went WOT and had no bog. So it seems like it occurs only in the powder. Lemme know what you find or if you have any ideas. Thanks
