well not that familiar with doos break in period. No BS about this, something serios with these machines. is it just these or has anyone else heard of this.DPM is old and should have all the bugs out. What did they change
Don't know what their symptoms were, but I had what seemed to be dpm/carboration issues with my '09 XP this weekend. It would load up so much at low RPM that it would barely idle. At times after I shut it off it would not want to start and I would have to hold it full throttle to get it to start. It ran great on the top end, this was just an issue at low RPM/idle. I have not consulted my dealer yet.
are your carb heaters off
change yur plugs?![]()
ta are seeing any of the probs that turbo al is seeing. he stated 60km track speed. doing cluch work and saying doubling the track speed?
150 posts and the only thing to be concluded is the 09's work about as good as a 1972 KittyKat. no RPM's, low RPM's, vary RPM's, loading up, wont start, recoil broken.........
There's always 2020, maybe, just maybe BRP can figure it out by then LOL
sleds running good now after ecm fix
So far I think the 09 set up is going to work
the 163 must have a lower gear ratio than the 154
I am running slp pipe, Y pipe, can, and 8-10 head
9-10 feet jetted at 480 no air box have my own cold air intake on currently
short threaded pins clicker 4
Found a good hill to make runs on yesterday
pulling a strong 8100 all the way am going to need about 100-200 more in deep snow dont like the way it runs in clicker 5-6 so i think I will pull a little more pin weight before I go again. If that dont work I will have a 20 tooth gear to try. Sled has a full vent kit and is not bulding much clutch heat.
110 miles on
should have 2 163's piped in a week or so---no heads yet planned on those![]()
Have these 2 ridden against your 154's?
HAHAHAHA - check this out, someone gave me a bad Rep mark since I said let's ride sometime, hahahaha What a putz!!! and of course too chicken$hit to sign their name![]()
here's the message...............
2009 XP first ride... 11-20-2008 10:56 AMI went ridding with darrel once, as long as you like driving in straight lines on the flat you will like him.![]()
