Has anyone seen the service bulletin from Cat regarding the 2010 years? They say "The ring gear bearing may not be pressed fully into place causing excessive side load of bearing part #2602-108." The ring bearing is part number 1602-980. My brothers 2010 M8 has been through two DD's now on warranty because of bearing 2602-108 failing. This is the bearing that people are replacing with the wider one. His sled is at the dealer now and I spoke to the mechanic that confirmed that the ring gear was not pressed on fully in the DD he ran this year (which was a full warranty DD from cat last year). There is roughly a 1/16'' gap when there should be none.
The interesting part about the bulletin is that it has a caution note: "Only use bearing 2606-108 (the stock bearing) for this application, use of a wider bearing will cause damage."
My dealer will not install the 5203-2RS bearing because of this bulletin and with it being a brand new warranty DD. I am wondering if Cat is correct in saying that if the ring gear bearing is pressed on correctly, the stock bearing is good to run.
There is no bulletin for the 2009 sleds, so I guess there ring gear bearings were pressed on correctly. My dad has a 2009 with all stock bearings and it is running fine.
I am unsure what to do at this point. Listen to Cat, Listen to BDX, listen to SnoWest... I was going to put the 5203-2RS in both sleds this summer and can still do so, but now that Cat says it may cause damage, I don't know if I should. The 2009 has no remaining warranty and the 2010 will be out in a couple months, before the snow falls.
Thoughts?
Brett
