P
i got a 2009 crossfire 600, will my barrings in there be ok because i have the act reverse?
Page one had the answer all along...
One of BDX's posts in this thread is completely wrong. It may be just worded poorly, but its still wrong. Be carefull.
Torn down my DD tonight after reading pages upon page of people having bad bearings with low miles and what do a find... A perfect bearing showing no wear or fatigue..
I must be the lucky one!!! Anyways for ****s and giggles I'm installing the double row bearing tomorrow..
All 2009 M and Xfire drive units came with 6203 sealed bearings. The 6203 bearing is failing because of excessive loads on the bearing due to the 1" further spacing that it has compared to the earlier forward only units. We have the 5203 bearing that is a double row bearing that will handle the excessive loads. These bearings are sealed because of the centrifical forces will not allow outside oil to get to the pocket bearing when at high speed operation. You can get this bearing individually or in the bearing kit. All 2009 M owners should replace this bearing to avoid future problems. Call us for info. 507-824-9966.
Ray
The 4203's out of the UK that people are buying on Ebay really have no "trail" where you can follow back to the MFG in China. I spent plenty of time talking to my rep from Motion Industries and then the engineers over at consolidated. I believe the 4203's from consolidated are high quality, and went into detail about the company they are using in China for these. These may not be Angular contact, but are certainly an improvement over what is in there stock. All bearings are not MFG the same, that is why I went with a company that has a good reputation in the industry.
For the 5203 to work on mine it was suggested from BDX to loosen the track shaft so I had enough clearance to close the cases, then tighten everything back together. I have heard negatives on this and I am not sold that is the answer. If you put any additional stress on those torx screws when tightening the case halves together you are asking for trouble as they will strip out faster than you can blink.
Really the easiest thing to do would be to run the single row 7203 Angular contact bearing which would fit perfectly using the shaft spacer. Also, Single row bearings are naturally more forgiving when a situation of misalignment comes into play; combine that with an Angular contact bearing and you can provide a nice bandaid for all the poor ACAT engineering.
Are the 4203 bearings sealed both sides? Anyone else used these with proven success?
On the 7203 bearing - doesn't it have to be installed with a certain side facing out? If so, which side faces which direction? I also noticed on SKF that some 7203s are made to run as individuals and others are made to run in pairs, just FYI.
I believe I also saw an SKF premium 7203 rated for super high rpm, but not sure if it is sealed.
Anyone know what rpm these bearings run at in the DD?
