Zbroz or Holz A arms?
If you ride alot and get an opportunity to switch between several sleds you can absolutely feel the difference in widths. I would prefer the stock width at the widest for this sled and for it's intended purpose. That said it's a rediculously easy sled to ride off camber so durability is my main thing. Remember that shock setups and rear suspension setups also cause the sleds to react and feel different. My PRO has a total Fox setup over holz. It's absolutely AWESOME to ride. Based on comments others have stated I'm pretty sure I'd have at least three or four sets of stock a arms ruined by now.
with those hits that you have been taking, have you had any issues with the bulkhead, thats the only thing that i'm nervous about, rather replace an arm than bulkhead.
The bulkhead on the PRO looks pretty stout from what I can tell....much better then the skidoo S and E modules that Im used to on the XP chassis
Polaris makes the strongest bulkhead IMO..if u Damage a bulkhead..you totalled your entire front end and most likely tunnel and yourself...a-arms are not gonna be intact with a bent bulkhead ..
This is the same debate they had when the stronger front bumpers came out..bumpers will break before the bulkheads sees anything. ;)
stock a arms and the bulk head
My buddy took my wifes sled for the time of its life last weekend, He got bucked off on the trail at high speeds, and the sled took the brunt impact of a large tree. worst impact ive ever seen to a ski, and right side a arms, and tie rod, and sway bar completley sheered off. only thing left intact was the shock and shock mount. Still didnt ding the bulk head! At 30mph plus!
2006 rmk 700:face-icon-small-dis
I put the 43" ARS-FX arms on with a set of 18" EXITS. Absolutely love them. Great fit and finish and from experience with previous sets they are extremely tough.
Did anyone ever weight a set of those stockers. Just curious to see if they are actually lighter than the Zbroz or just weaker.
Anyone have the accurate weight of the 2011 or 2012 stock A arms?
