looking to get some Aarms for my PRO. Is there any differences between the 2? Holz claims they are 3 lbs lighter then stockers
Take care in elevating your front on this setup. It changes everything about the geometry of your rear suspension and how it works. We found you have about 2" max a variance before you really mess up how things react.
do zbroz actually increase the heighth of the sled or does the clearance gain come from angling to arms down toward the spindle at the end of the arms to gain a-arm clearnce rather than raise the height of the sled.
great point about the sway bar. Im not seeing it. Zbroz is giving me a call back later this afternoon.
Also:
Zbroz Lifetime warranty on Aarms
Holz 2 yr warranty
Zbroz Aarms are 2lbs heavier then stock Aarms, Holz are 3lbs lighter then Stock Aarms.
Holz includes Chromoly Tie rod ends
Zbroz (40) do not include Tie rods
Zbros come in black but can be PC'd another color for $50 upcharge
Holz can be black or red at no extra charge
Do Z-Broz even need the new tie rods since the arms are the same length as stock?? I thought HRP's were included since they were 41".
I've bent plenty of Holz on the last sled. I get the "a-arms are cheaper than bulkhead" argument, but every Holz lower I've bent I've scratched my head wondering "what the f#@k did I hit!?" I'm tired of buying replacements! I think I'll try the Z-Broz this go around and see for myself (plus I'm still angry about my HRP 90 some odd $ clutch side vents).
I don't know where you guys are getting your weights from just measured them and:
Stock: 11.43 w/ ball joints
ZBROZ: 9.33 w/ ball joints
Mine just came in today and they have a cross piece welded in for the 09-11 sway bar style.
That weight is per set.
You're probably right. I measured a 2010-
I heard the oem 2011's are the same dimensions but lighter weight
The zbroz are the same from 2009-2011 except the bushings are larger on the 2011's.
Can anyone weigh a set of 2011's
http://snowhounds.smugmug.com/photos/1149043817_D2gXG-Ti-0.jpg![]()
