Turbo 860?? Or ET 860?? Just clarifyin...
So back to the hot soak thing. In theory then if I am running 100 deg water temp and piston/cylinder temps are 300 or above the motor is hot soaked?? And if I raise water temp to 160, piston/cylinder temps would have to be 360 to be hot soaked??
So correct me if I am wrong, what you are basically saying is that on a long pull the 800r motor is building too much piston/cylinder heat and that is causing it to drop horsepower which would lead to a drop in rpm and trackspeed...correct??
So, what is the best way to get a handle on this?? Richen the jetting?? Raise or lower water temps?? More oil??
Thanks alot, tons of good info on here!!
Jake
The only real cure is to not make HP, no one is willing to do that. But there are things you can do to slow it down. More oil is great start, correct squish and quinch band on the head, little on the rich side, 50-100rpm high on clutching from peak hp, higher octain fuel, better quality oil.
Oils that have failed all my tests, Blue marble, Skidoo semi synth-aka golden spectro, cat none apv oil valvaline 2 stroke.
Still the best and only complete molecule chain oil is Castor bean oil. But in cold weather creates many other problems so hard to use.
On my big hp outboards we use a fat or washdown button, its where we spray the gas solenoid of the nitrious system with no nitrious to fuel wash the piston before we shut it down to reduce piston wear or siezed pistons from long hard nitrious pulls.
