sledskiing
Went to home depot today and got some winterizing supplies
- aluminum foil insulating tape
- foam pip insulation
- fiberglass insulation filler
- blue foam insulation board
- Heat tape
used the aluminum foil tape and foam pipe insulation in as many areas as i had access for the hot water supply lines and used foam pipe insulation around cold water lines.
Blue foam insulation around the exterior walls under the couch where the fresh water tank and hot water tank are.
Used fiberglass insulation filler in tight areas around the tanks.
My heating is ducted and the ducts run in the cabinets where pipes are. This should help prevent freezing.
I will use the heat tape on any exterior plumbing.
When winter gets closer I will use the 3m window stuff.
I will also be cutting small vents into the cabinets and under the couch so the heat can get circulate.
I'll probably do what Bushmaster does with the grey water.
- Heat tape
