Think about it from this perspective for a second...
What if they build them this way on purpose? Just so they can sell replacement parts to make more money. I have to think based on the history of the 800 cfi this at least some what has to be true.
Take Polaris for example. I think most can agree Polaris builds a great chassis.
People are willing to buy a sled with an anemic engine basically just for this chassis.
so if its mostly about the hp/cc of the engine, and i understand and agree these are pretty high strung small engines pulling severe duty, but once again why is it that the lowest powered engine in the class has the highest failure rate and engines like the m7 and D7 put out ruffly the same horsepower but in a smaller displacement which would intern raise the hp/cc ratio even higher seem to last alot longer? i dunno about the poo 700, but as far as the shorter strokes and all that stuff people are saying as why the 7s last long if i'm not mistaken the m7 is the same stroke as the m8 so that should take that theory out of the water shouldnt it?
my m7 has just under 4200 miles on all original internals and the majority of them miles are with the flipper held to the bars in off trail mountain riding and still runs like a raped ape. it has also had a modified head and SW single pipe on it for the majority of its life which "should" in turn create more ponies which would just increase the hp/cc ratio right?
so from my understanding the pro is ~800cc's putting down 135-145ish hp depending who you ask, and my m7 is ~700cc's putting down roughly the same hp then my hp/cc ratio would in turn be higher than the poo. soooo from my calculations, if you take the poo failure rate......carry the 1........ dot the T........ roll this # over..........add this #.......and round here, my sled should have blown up roughly 8 1/2-9 times by now.
guess what i'm sayin is i lean more towards its a manufacturer issue than simply hp and displacement issue with why some last and some dont.
P.S.-hopefully cat wont screw up the best thing goin for them when they start producing there own engines.
P.P.S.-i'm bored
you wont get any thank you's for that one.LOL
Big difference between flatland and mountain miles also. Not picking a fight, just saying.
^ I think I already answered that about 5 times, but I'll try again....
It's not that engines can't live at this specific out put. They can....they do. They can live at significantly higher specific output levels, as evidenced by the many boosted 800's running around, some of which with lots of miles and minimal issues.
All I'm saying is that the higher the specific output, the more it exacerbates any small flaw (design or manufacturing), inconsistency, tolerance issue/tolerance stacking, lack of maintenance, improper fuel or lubrication, etc, etc, etc, etc.....so when the manufacturer's have a small "miss," it can easily lead to catastrophic engine failures. Even your M7....they were a reliable engine in general, but it's not like no one ever blew one up. It's not like the dealer never saw the odd one in for a motor job. My truck has a Toyota 4.7L V8 that is used in 5 different Toyota/Lexus models across 9 model years....I worked with Toyota for about those same 9 model years, and you know how many 4.7L engines we replaced or rebuilt? 0....as in 0 ever. Why can that happen and it has never happened with any sled motor? 2 things.....one is money, and the other is the nature of the beast. Why are some better than others? That's a technical question and you would really have to get into the math and materials of each to compare. Indy Dan had some great techincal discussion on the Pol 800 in the Pol section if anyone cares to look it up....
I have 3600 miles on a boosted cat motor. Some mfgs hire someone else to make motors better than others.
