I'll do some digging on this...
2112..... can you post a photo of your spindle install taken from multi angles?.......................
.................If you were to take a long 3/8 bolt and put it in thru the top ball joint hole in the spindle... would you be able to push it thru into the lower hole as well?............................
That does make sense. I know I said that mine fit on with no problem but I have a Switchback with the longer A-Arms. I apologize if you got the wrong information from me - I did not take the shorter arms in consideration.
(holtz, 09 stockers, timbersled etc.)?
also, can you put just the timbersled spindles on the stock a-arms, or do you have to buy the whole kit?
Diamond Dave: As for the toe in issue on this sled, I haven't run into this. I think something else is going on.
These are IQR spindles on RMK arms... with RMK steering linkages and rods.
I think yours were HRP brand RMK spindles???
