... Just be prepared to service the stock shocks at short intervals.
If, in your frequent service you are requiring, you are changing the oil and recharging the nitrogen... and not changing shims/seals... That would be a shock oil issue... If the valving or piston orifices are not ideal... they can certainly "scorch" your oil... even good oil.
That "scorched" oil is most often not caused by not having a resi... on what is, essentially, a snow cooled shock... it is the valving spec.
Heck... the whole shock itself rarely gets hot on a mountain sled unless you get your kicks from 20 miles of endless mogul bashing on the trail (like on the ride to the Pamby Ice cap from the Rutherford, ouch)....but a "cool" shock can still scorch the oil... and scorched oil does not work well.
Thermal fade is not a situation where you simply have scorched oil... It is where the oil and shock are too hot... rarely does this happen on a mountain sled like it would on a snowcrosser etc. Thermal fade is not permanent and goes away when the shock cools down again. Thermal fade and scorched oil are two separate things... although multiple cycles of thermal fade can lead you down the road to scorched oil.
A remote resi shock, on a mountain sled..... has as it's prime feature, the ability to vary the compression side damping through the use of a secondary valve stack and a valving-preload-adjuster (clicker), something a non-resi shock cannot do with consumer offerings avail today.
Even a remote resi shock can experience scorched oil if the valving and piston are not designed well.
On the Walkers, with what TRS has shown me... the stock mineral-oil shock fluid is lower quality and the fluid literally wears out quickly. A switch to a better quality shock oil, like Raptor or Amsoil full synthetic will make a big difference in necessary service intervals for the shock.
All that being said, the factory, to produce a sled that has a reasonable retail price, cannot afford to put top end shocks like Raptor, Fox, EXIT etc on the machine and still turn a profit that looks good at the annual shareholders meeting.
