Will a 2010 boondocker turboed m8 be safe up to 14lbs boost on straight
VP C111 ? Believe its 108 octane. Or will I need something with a higher octane rating.
I think they have good service and Ken seems like a pretty nice guy. But they seem to over charge on everything. I agree about driving to Calgary and deal with Jordan directly. If you buy 4 or more barrels the price gets way cheaper.
I buy my fuel from small&sons in auburn WA 98002 1-800-626-3213
They have turbo trick which has a motor octane of 109 and a research octane of 119 specific gravity 0.739 and 6.15lbs/gal.. This stuff works great and is only $8.98 a gal US. I would only run around 15lbs of boost with it though. For the people going for the boost they have drag fuel m/o 114 i was running in the 20s with this last year. That is only $11.89 gal. US
Remember that every time you change to a different kind of fuel you will have to change your numbers in your EFI box because of the different fuel property's.
If any of you are interested in getting this fuel let me know. and ill see what I can do
I have change my mine about what fuel I will run. Hopefully I can get som Efl Moto 124. Will be a perfect fuel to run. 110 MON. It cost a little more then the VP 109 but it is so much better. The VP 109 is 1140$ /Drum.
I Run C111 on my 2009 m8 up to 12lbs. And switch to C12 to run 14lbs
seems to work good but I think the octane levels are close to the same but C12 is a better grade of fuel, its about $100 more per barrel. Give Jordan a call at VP Calgary 403) 275-1958
I just picked up a bunch And it was cheaper if you buy them four at a time.
