I think he cut the track down to 2" from the 2.4" with a electric carving knife. Am I right?
The head is a good way to go for more perfomace at a lower cost. There are several brands you can go with, SLP is my choice. F-Bomb has a head on his Pro and I must say it works well and it seams that is was a better price than alot of others. Hope he will chim in here and help you out on the brand name, He is at the snow show this wk end, come on Rob put the cup down and help me out, LOL. I know alot of us are looking for a little more out of our sleds, and his was alot of fun to ride, and it did not hurt your pocket near as bad.
Power Addiction head and the track mod is taking it down to 2 1/4"(just under the teeth). Lots of posts on this.
This.
So many track experts with zero time on a Pro... Carl's told me the 5.1 was stiffened slightly from the Dragon 5.1 - whether that's true or not I can't say. I CAN say that it works very well on the Pro part of which may be due to the excellent track attack angle and the 50+ lb weight loss of the Pro over the Dragon which wouldn't fold the paddles as much. Combine that with cutting just the tips of the paddles off and you get the proper stiffness, save even more rotating mass, and have a helluva lot more track speed than going to a C-Xtreme (weighs a good 10 lbs more) that will need a D&R chaincase mod, new drivers and overall cost a helluva lot for questionable performance gains. RIDE THE SLED FIRST is my advice!
Have FUN!
G MAN
This.
Have FUN!
G MAN
Not following how your post relates to my quote. Care to explain?
What do you call excellent track attack angle, the pro has the steepest approach angle out of any from what I have seen. The reason it works is mainly 1, its light, 2, the geometry and suspension makes it work. The way polaris designed the skid is very interesting because of the this, even though the approach angle is very steep what they accomplished by doing it is more track on the ground. The Pro 155" puts nearly as much track on the ground as a cat 162". So you can imagine why it get on the snow, also by doing it they put the track on the ground farther forward which helps in rider input, look at any of them and you will see the track hit the ground under your feet on the pro but not on the others.
I know of a guy that ran the 5.1 vs the PC on a pro, said the 5.1 seemed better at low speed boonedocking and the PC better if you had a little momentum.
The Assault has a "normal" attack angle. The Pro purposely has rails barely turned up and has the shallowest approach angle I've seen (to what I'm used to on a Summit). Are you looking at the Assault or maybe I'm the ignoramus here???
Have FUN!
G MAN
First sentence MEANING exactly what you said (THIS). You must be older?
The rest relates to previous posts, for those that have never ridden it, and had nothing to do with your post other than explaining the track mod!
Cheers,
G
Oh, you said "this". I didn't realize you said "this". I also didn't realize when you stick the word "this" somewhere, that it is actually constitutes a sentence meaning to agree in some form. I guess I am old.
This is a great kit that works, best head design.
http://www.terraalpsracing.com/product/polaris-rmk-pro-800cc-cfi-2008-12-performance-kits
engine kits, clutch kits, tracks, extended chaincases etc...
Cheers,
Just to clarify, you are the manufacturer and your endorsing YOUR own product as the "best head design"? Some may be unaware that you are vouching for your own product, not an unbiased customer review.
