Does anyne know hwat the best Preformance mod is? heard good thgings about getting a head but anyone know anything that might be better?
Getting head is always good. Like stated above it depends on budget.
Head baby ,Everyone deserves good head!!!!!! AND No I dont give either !!
@1200PSI
With your power addiction head could i run the 13.1:1 comp ratio head around where live at about 1800 feet? what fuel requirements would be nessicary? and would you happen to know the stock compression ratio?
Also kinda off topic here but, What EXACTLY does the ethanol resistor do? Retard Timing? Add fuel?
you are correct. 5% fuel throughout, no timing.
from a pure power stand point,
i added an slp single last year and was surprisingly impressed with the results. had to add two grams of weight and was still holding better rpm. actually much more noticeable than when i added the single to the dragon. but just the single will cost you much closer to a grand than 500. got mine used (although essentially brand new) from a friend for 800 and was quite happy with the price.
now if you only have 500,
then i would probably seriously consider a set of airframes (if you can find them) before anything else. i was that impressed with them and i've had SE and BB in the past. i won't own another sled without them, or something extremely similar. although brad is saying there are some real nice gains with his head and the can, but i haven't added his head (yet) so i can say personally. when i talked to him, brad said that if i wanted to run the 13.1:1 head i would need to add about 30% av gas. more if i wanted to run the 13.6:1 head. i run from 0-5000 feet so my guess is he'll probably recommend they same for you. of course it may also depend on how high you ride on a regular basis. good luck
pv
YEah well i dont think i really wanna be mixxing gas, what about with brads 12.5:1? would it even be worth it? also could my buddy run a Boss Nos kit with the head using a 20 shot of nos?
what type of gain hp will i get with the can and the 12.5 head ?? can i ride it from 1800' to 10000' with no changes?
