I thought the test looked pretty legit, now I will spend some time kicking ice off. I have the polaris burandt bag and I originally didn't like how big it was, but I have almost no ice build up on the tunnel!!
Aight....math class back in.
Leave the poo out for a sec. The Doo started out lighter, and by the end the AC gained 36 LESS lbs that the Doo.
Just that 36 lbs would be an extra 4.32 GALLONS of water. Don't think 4.32 gallons is a lot....go pour 4.32 gallons of milk on your shop floor and let me know how much of a mess it makes. And that's just the extra that Doo supposedly holds over the Cat....not the total. Keeping in mind that Doo has all the same powdercoating/painted bits.
Further on that, lets say ice melts 1:1 into water (close enough). Snow melts 5:1 into water or less....so 5 gallons of average snow would give you 1 gallon of water. So any powdery, light-ish snow is adding very little weight without a HUGE volume of it.
With the pro....they are saying a gain of 94lbs. 94 lbs would be 11.30 GALLONS of water melted off. Over two 5-gallon pails full of solid ice, or over eleven 5-gallon pails full of snow....however you want to split that up. I always park my sled in a heated shop right after riding, and I know what 11 gallons on the ground would look like from my gas station days. It ain't that.....not even close.
Get out the hip-waders....it's getting deep in cat land. Bottom line is....they are trying to justify having the heaviest sled.
This is my first post in years here but this is bugging the crap out of me. You guys are assuming that all the extra weight is snow weight. We are talking about DRY weight to fully loaded WITH snow, that means, add anti-freeze, oil, gas, shock fluid, brake fluid, chain case fluid, etc. There are lots of variables here. For one, cat probably used a snow pro with fox floats so no fluid there, which of these sleds holds more oil, gas, antifreeze?
Video is private now. Guess I should have gotten my laughs a few days ago.
Ok so here's the cat promo video about riding weight:
http://www.youtube.com/watch?v=IbbeK93CVrQ&sns=em
I feel that that is a lot of snow as well, but seems pretty well thought out and accurately done....however....They measured 94 lbs increase on the pro and 47 lbs on the cat, and the pro was STILL lighter. Only by one pound but still lighter.
I know that this tells me a tunnel top wrap and nose cone block off plate are in my future, possibly a powder coated chassis or cf tunnel...
If the differance of a painted/coated to shed snow sled is 50 lbs in riding weight then I'm going to take the lightest dry sled, with the lightest riding weight AND the eaisest one to improve riding weight on and make it an even better sled.
on another note: i just got all the small tree branches and pine needles out from under the fuel tank and around the engine belly pan. i weighed this debris and was shocked to find i was toting around 2 EXTRA pounds with me so far this season. you would think after forking out good money that the manufacturers would address this issue. class action lawsuit forthcoming lol![]()
