Blessed with the small genes boys my buddies that are 200 pounds dont even try an play the high mark game hahaha!!!
Anyone on a proclimb losing to a pro doesn't surprise me because the clutching is **** stock. I let my clutches cool down and i would be 6 lengths ahead, when i was hot, he would beat me....
Keep them clutches cool, set the suspension up and the proclimb will win strait up the hill every-time.
We had an 11 pro rmk and another 12 hcr that was left stock riding with me all last season, i tested mine against both as i modded all year, i have posted helmet cam footage of some of the testing
right now my sled with mds weights, and a team secondary i beat the pro rmk and the stock hcr by several lengths a lot of that is out the hole bite/go
When we put the orange spring in the stock secondary it really woke it up out the gate
But was 15 degrees hotter
I set the rear shock just to the point it gets proper ride height, then adjust the front track shock in till the front end lift is controllable under a launch. This gives your sled a "jumps out of
The hole" feeling when setup properly.
I think the single best shock to upgrade is the rear track shock, i think its a lot of the reason the pro rmk skid works so good.
Having a smooth gas shock for your sled to transfer the weight to the ground with is huge. As you pin it the sled rocks back on that shock, if its not getting all its travel because you have the air pressure so high ( if you weigh 200 pounds) the shock is going to have stiffer bottoming out characteristics. Making the skid trench.
Just setting up the rear suspension properly will get you 2-3 sled lengths in a 1/4 mile if not more!
Both sleds setup right i give it to the proclimb, now if cat would just come set up out the box we would be doing just fine. It was the first year though...
Polaris is hitting a home run out the gate, but they also have a few years on there chassis!
Just remember first year sled
Wyo if im wrong anywhere feel free to enlighten me as im bring up the discussion to learn more!
-Aksnopro
