it's not like those companies have the means of BRP either.I have never felt the aftermarket snowmobile turbo world had much innovation or progression at all. Why that is I can think of a few possible reasons. My best guess is they didn't need to and focused on making money. I don't believe they can come close to competing with a company like BRP if they decide to do this but it should be a closer gap. I could be completely wrong just my view.
Junkie, heat is a necessary part of it. Even if you had a cold tank of air to "fuel" the motor and turn the turbo, you would still get heat.
Anytime you compress gas, it builds heat. You would be heating the air up in the motor then heating it up again to build boost. They don't call the intake side of the turbo the angry charge because it's cool.
yes when air is compressed it heats up but in your example, this is a side effect of compressing the air and really doesn't pertain to the question of heat in general in terms of it being a necessary factor in spinning the turbo. in other words, if it were possible to compress air and not have it heat up, the turbo is still going to spin. and to put it another way, say you have two free standing identical turbos and you run ambient temp air thru one at a specific velocity and you run exhaust gas temp air thru the other at the same velocity, i'm betting any difference in turbo rpm will be neglibible if there's a difference at all which means heat doesn't matter. actaully, since cooler air is denser and has more mass per unit volume it may act more forcefully on the blades and spin them at a higher rpm. interesting stuff.
for an ICE, exhaust gases are completely wasted energy, unless you have a turbo recovering some of that energy. no on is denying base physics.And were does the airflow / energy comes from in your "lab" example ?
The air compressor was feed electricity and then generated airflow. This is why your exemple doesn't work. You isolating a part of the system and not taking everything into account.
Start with the basic of physics:
Nothing is created
Nothing is wasted
Everything is transformed
Sent from my BV9800Pro using Tapatalk
That is debatable IMO. On a 4-stroke motor, a turbo robs power from the motor (initially) because it is resistance in the exhaust that the movement of the piston has to push. In other words it adds a load to the motor that it has to move. Then of course the benefit outweighs the cost once the turbo spools up. On a 2-stroke it is a debate because backpressure is needed in the exhaust to not loose the next fuel/air charge for combustion, but resistance or backpressure DOES put a load on the piston moving up and down. So COMPLETELY wasted energy is not really a completely true statement. Bottom line is that an ICE is all about moving air, the more you can put in the more you can get out (power), and any resistance to airflow IS a loss of power, even if the resistance of a turbo is obviously an exchange for a small initial resistance of airflow to an eventual greater amount. That's why there is lag in a turbo. You loose some power initially in exchange for greater power once spooled up.for an ICE, exhaust gases are completely wasted energy, unless you have a turbo recovering some of that energy. no on is denying base physics.
your turbo act as recovery system making your engine more efficient.
you could go deeper, if your electricity is generated by a water turbine will you say your compressor runs on water?
Not debatable at all. It's physics !That is debatable IMO. On a 4-stroke motor, a turbo robs power from the motor (initially) because it is resistance in the exhaust that the movement of the piston has to push. In other words it adds a load to the motor that it has to move. Then of course the benefit outweighs the cost once the turbo spools up. On a 2-stroke it is a debate because backpressure is needed in the exhaust to not loose the next fuel/air charge for combustion, but resistance or backpressure DOES put a load on the piston moving up and down. So COMPLETELY wasted energy is not really a completely true statement. Bottom line is that an ICE is all about moving air, the more you can put in the more you can get out (power), and any resistance to airflow IS a loss of power, even if the resistance of a turbo is obviously an exchange for a small initial resistance of airflow to an eventual greater amount. That's why there is lag in a turbo. You loose some power initially in exchange for greater power once spooled up.
with no heat; a engine, compressor or pump will not turn. Since friction IS heat.I never said you wouldn’t get heat, I’m saying it isn’t NECESSARY to make the motor turn.
If heat plays no part in spooling a turbo then why can't you spool it just by revving the motor in neutral? A motor needs load to spool which is proof that airflow alone won't cut it.
so from your statement is it correct to say that an engine under 100% load but having the exhaust gasses go thru an intercooler to cool them to room temp and then into the turbo won't spin the turbo? if it still spins then that's proof that heat is not required to spin the turbo and i don't see how that's different than placing a pinwheel in front of a fan because the pinwheel will definitely spin.If heat plays no part in spooling a turbo then why can't you spool it just by revving the motor in neutral? A motor needs load to spool which is proof that airflow alone won't cut it.
that's what i was thinking but couldn't articulate it.You can spool up a turbo in neutral. Whether it is in gear or not has absolutely nothing to do with a turbo spooling up.
I don’t think we’re debating the same thing. Physics doesn’t require heat to turn a turbo, only airflow. Heat is CREATED when the turbo turns but heat isn’t NEEDED to make it turn. If that doesn’t make sense, I don’t know how to explain it any better.
