my understanding is the rb3 can not be mapped for more than about 16lbs, Paul tried it last year and could not get enough fuel for hi boost had to piggy back controllers to get the fuel he needed, it does have alot of good things going for it but if it can,t control fuel at hi boost 20+ lbs. its of no use for me. has anybody mapped it and got it to work at 20+ lbs.
I have had mine up to 16-17 pounds with Daves HP kit (Apex) and still have a bit of room to go up more with a 2/1 regulator at 43 pounds at idle with stock injectors.
I have larger injectors sitting on the bench and will install them as soon as I find the limit with the stockers. With the RB3 you can install the larger injectors and then back out the fuel on the bottom for drivability.
I am not sure why Paul could not get more out of it. The limiting factor at that point would be duty cycle on the injector. I know he has worked with larger injectors so I don't know why he would be limited to 16 lbs.
How would "piggy backing controllers work??
I do agree that most people just want to plug it in and go but with a turbo and all of the varibles of elevation, boost etc that is alot to ask for........... Same goes for "pump gas turbo that is reliable" is there really such an animal????????
With the way the RB3 works it is pretty consistent over a range of boost #s because it is load based off of a 2 or 3 bar map sensor.
I run a 3 bar map sensor which gives you 27.4 lbs of boost to work with across the top load bar. You can change the %'s at the top to what ever you want. It is good to have the first column on the left to be 0% so you come on the map right away. Then it is just a matter of what the map sensor is getting for boost signal and RPM that varies where you are on the map. Like most controllers by adding more fuel pressure or increasing the size of injectors to stay in the efficiency range of the injector you just adjust the map accordingly.
You can see the load % across the top. Say you are at 16 lbs of boost. You will be in the 60% load column based on the 3 bar map sensor giving you 27.4 lbs spread across the 100%. 27.4x.6=16.5 lbs
This is why as long as you have the proper injectors or fuel pressure it stays consistent across say 4-6 pounds with one map. It will not be long before there is alot of maps available for many different conditions.
Here is an example of a map. The first one is fuel. The second is IGN.
Fuel
IGN
Hope this makes sense!
