i have mr rmk with the 133 and i am going to a long track in the summer i have the 600 tripple with 34mm carbs all stock except skis. what track will still keep me on top of snow and my 600 be able to push. i want to go as long as posable
I think 151 is about the limit. 154 and 162 will need different drivers and I am not sure you have enough HP for those unless you gear it down a bunch. Depending on what chassis you have, you may need drivers anyway to clear or a rolled chain case.
The drop n roll is not that big of a deal, just time consuming. They sure work better in the powder after a drop n roll. They really shine in wet powder, the slush does not jam in the front of the tunnel as bad. The machine seems to roll freer also, must be the flatter approach angle.
The XLT chain case will only accept a 40 or 41 tooth bottom gear. Mated with a 18 tooth top gear will get you 2.22 or 2.27 ratio. I would not go to any smaller top gear. Those ratios will be fine for either the 144 or the 151.
8 Tooth drivers go down another 8% I believe so final ratio could be in the 2.4 range. If you go smaller drivers, I would use a 19 top gear, it will wear better.
Also, with your minimal suspension travel, you won't have as much clearance once the track starts digging until you are hung up on your running boards (remember the coolers are under there taking up room on the older liquid wedges).
Wait until you drop into a trench made by a bigger sled. Then you'll know what I mean by hung up.
i have slp plastic skis my questions is will a 2 inch lugs fit with the stock drivers and know drop and roll it is a 96 xlt rmk 600
