Hi so I need instull only yellow spring in secondary and it will help how about primary?Do I need to change spring too. Thanks.
I was responding to the statement in post #87....
Teth-Air said:I agree [to what Winterbrew said, "More secondary spring= stronger backshift", so how does turboal explain the increased backshift equating to higher track speed? This sounds backwards to me? I expect higher track speed to come from the belt moving higher in the secondary not lower, after all isn't a stiffer spring going to slow the belt from climbing the secondary?
Has anyone tried using some different springs in the primary with the 225/350 secondary spring?
I wonder what would happen with a spring with a softer start??? (ie:130/290 rather than the '09 stock 160/290)
What about something with a little more finish??? (ie: 160/350 rather than the '08 stock 160/320)
Don't work. I ran mine with a 130/290. The primary worked a little better but no like it should. remember the primary and secondary server different roles. primary RPM sensing and secondary torque sensing. You can fix a bad secondary setup with primary and vica versa. My feeling is the ramps in the 08 clutch are junk also. the need to have a more aggressive shift all through the curve, espically in the bottom. all the XP's I have rode rev like a SOB down the trail..that's becuase of the lazy shift on the bottom. The primary also shifts out so far while climing then just stops...with lower gearing this is even more noticable. I am expermenting with new ramps this year...much more agressive shift and then adding the stiffer secondary spring to fix that issue.
I bet this is why skidoo went to the reverse cut helix this year is to give more shift on the top...but again it's a primary issue so fixing it by putting in a steeper helix is the wrong way to go imo.
Throttle Junkie; Can you describe how the primary worked better with the 130/290? Also, what are your thoughts on the new 441 ramps in the '09's?
Well I was trying to get rid of the "revyness" on the bottom and going up the trail. The XP's have no "bite" until you are wide open. On the trail they just rev and you can tell the motor is not loaded at all. I was hoping that the softer spring would help with this. Also, while climbing you can feel the primary shift to a certain point and then it just stops like it runs into a wall. The sled has the power to keep shifting but does not. So in theory the light spring and more pin weight I added should make it shift harder. It did a little but not like I wanted. Basically you are trying to over come the "steepness" of the ramp with weight and soft spring. What I don't like about heavier pin weights and softer spring is it make the sled too sensative to conditions, alltitude, trail and off trail conditions. Which it was. One pull would be 8150 go around the hill to the other side of the mountain and it would be at 7800...
This is my first ski-doo but I clutched and worked on Polaris Mods for years and learned you want just enough weight to achieve full shift and RPM's but any more is messing up the setup.
With the Ski-Doo you have the option to change the ramps also which effects the shift. So what I am expermeneting with is taking away pin weight, going back to the 160/310 spring and running much more aggresive shift ramps. (if you look at the 08 ramps the have a huge belly in them on the bottom which causes the revy condition, basically it's in first gear going down the trail) and you can't add enough weight or softer spring to overcome that without messing up the top, hence why I think the 08 ramps are garbage. As far as the new 441 ramps, I don't know much about them. What I can tell you is I am not using any ramps that were made for these clutches. I have a buddy who raced and ran turbo ski-doos for years and I am putting some old school ramps in it. They are currently getting modified so they will work.
Once they are in and we get some snow I will let you know how it works.
I also dislike the "lazy" feel of the factory settup, different ramps can make for a very solid, aggressive feel.
You also need to install the updated 09 spring cap in the primary
part number# 417222759.
standard part of my equipment in my pack is my infared heat gun .lets ya see the slip .the gps is another , speedo when you can see it .
slip will vary with the varied types of snow consistencies.
this motor is tough to clutch to due to the very narrow oporating powr band
is why it tend s to like a more sensitive back shift .
if you think you are stalling the up shift , look at the speedo and very ify it,
it is something you feel and hear , least i do , a lot of roaring and no change in a track speed , like it hit a wall and then you glance at the speedo and go oh ,
same when it never quits accelorating , no questioin there , you feel it .
for some guys its finding the max , others just feeling the breeze is good enough .
track speed is a variable and will range due to snow consistiences but you get a good idea what it averages .
poor fitting clutch components is more of an effect on this sensitve motor than the previous one . so this years has a better start .
i would expect to see the 146 run close to 58.60 average track speeds in our area . 154's 54/58 and 163's 50/54 mph .
these are pretty respectable but do reflect what i expected to see the tunnel design deliver as compared to the previous chassi . is what we got out of the 08 and was an average of 7 mph quicker than the previous rev chassi.
it takes a lot of playing and we tried a large spectrum of springs and ramps to find what all would happen.mostly trying to find the edge of the pull on the motor . with such a late power valve opening it makes me wonder if doo could consider putting a switch on the dash that allows us to electrically choose a 5800 opening for the mtns and a 7400 for a trail pass to pass sound emmissions . mtns we dont need to pass the stringent test and could really use some added mid range power .
when this is done the low end pull of this motor is excellent and can be made to feel very electric.
here's a brain teaser for ya .
if you took the primary spring out of the clutch and threw it away .
how many grams of weight would it take to drive the clutch forward with out slipping?
You can run any clutch without a spring, but why? It's another tuning aid that allows you to further manipulate the set up to do what you want.
