A P-85 and a TRA commonly use springs very similar in force. So it's not just a TRA that uses a spring to aid in tuning.
I have found that using MORE weight, whether in a TRA or a P-85, in conjunction with a bit more spring (nothing excessive) will make things more consistant and better hold track speed under heavy load situation (climbing) than a setup that uses lighter spring and lighter weight. This has been consistant on different sleds and different brands and styles of clutches, including the old cat hex clutch which is functionally identical to a Polar. I recall changing ramps, springs and weight in those back in the '70's.
I'm a bit confused on this statement...."as the TRA was doing some of the secondary function already which was to easy up on the belt grip at the top of the sheaves at full power due to the emourmus spring pressure in the TRA".
Actually this was because of the geometry of the arms.....they just can't squeeze as hard at higher shift ratios....this was compensated when they went to the variable sheaves, the shallower sheave angle allows easier shift out on top end while the steeper angle down low helps hold the belt when there is a smaller contact patch.
The TRA does nothing as far as backshift, that is all the job of the secondary....as long as the TRA (or ANY primary) is spinning, it is creating force against the movable sheave. With a proper spring, this force can be better regulated and "dampened" to not be overly sensitive which would make for more RPM fluctuation.
Dang.....I need snow!
