ok, so i had a 03 900 MC, and was getting seriously beat by a 03 Poo 800 RMK with full slp setup. Now i have a 07 M1000, stock engine, but 162 PC track, and i still get beat by it. riders r similar weight...etc. Whats going on? i thought i would spank him...whats going on? im tired of getting beat
no its my bros sled and hes not running a turbohe has the stock rmk 159 track, just a full slp exhaust kit and slp intake. what kind of clutching setup r u guys doing for you M1K? i know i shouldnt b getting beat with that sled. I just bought my sled a couple days ago so i have no idea what the clutching is.
The M1000 takes four spark plugs, i would install the other two and run the poo again
So was he beating you in a drag race or climbing? I put a powerclaw on my 08 M1000 last spring thinking it would give me the edge when climbing against my brothers 08 M1000 snopro, sorry to say that i could not touch him. I think i traced the problem to a worn out belt and very low air pressure in my rear shock but we will see this year. My sled always seemed a little faster as far a drag racing goes, both sleds are stock other than MBRP cans and mine has the Powerclaw. Try cleaning the clutches, a belt swap and break the belt in gently for about 30 miles. I was also told by a highly respected engine builder here in Alberta that the stock M1000s like an extra gram of weight and the 046 belt, the 060 with Kevlar get sticky when hot.
you better take that m apart and find out what is going on clutches,suspension lots of info on here that poo even good running if thats all its got will not beat that sled. waite a minute maybe its you switch riders
hmmm ok...im revving around 7500 rpm according to the cat rpm gauge...but im running 80 grams already. We never ran past 50 mph, but i noticed it doesnt like being run fast. personally i dont care about winning drags....i wanna kick butt in the steep n deep![]()
7500! too high! I have owned three 1000's and always through weight at them out of the box I have added weight to the primary to get the revs from 7000-7200 it loves it there!
at 7500 rpm you probably are running less HP and torque than the 800's! power drops off hard after 7200 rpm
on all my 1000's I would run a can and a Y-pipe only no fuel controller ever, I would run them anywhere from 2000ft to 8000ft like that
the 1000 has only one disadvantage and most of the time its the setup, she is very finiky about the RPM's
give it a try!
B
Hate to say it but 250 ft is not what i would call a race. You are probably spinning way too much. I have an 06 m7 that hangs with our M1000s for a hundred feet or more until the 1000s really start to hook up, then its game over for the M7.
Not trying to highjack the thread but how much extra weight were you adding? I actually just bought the Dalton adjustable clutch weights and will be installing them in a couple days. Stock weight is 80 grams and 81 was recommended to me by a respected engine builder. Just curious since i ride the same type of elevations and my sled also has an intake, Y pipe, can and shaved head. Thanks.7500! too high! I have owned three 1000's and always through weight at them out of the box I have added weight to the primary to get the revs from 7000-7200 it loves it there!
give it a try!
B
