We felt that the industry needed a bag that nobody made so.......we made it.
Most tunnel bags are one compartment, sitting right on the tunnel of your sled. You cram as much stuff into it and when you need something you end up emptying the whole thing to get the one item you wanted. The other problem that many of us have experienced is condensation building up in the bag. The heat from the heat exchangers hit the cold air in your bag and moisture forms.
After a full season on the snow we have had NO reports of failure from customers or during our continued testing.
Problem solved....
Introducing the E-Series (Explorer Series) Tunnel Bags from Sled Solutions.
E-Series Max $179.99
E-Series Mini $159.99
Features:
• 99% waterproof – The bag is everything but submersible but you can count on your content staying dry as the bag has been designed using materials and sewing practices that eliminate places for water to get in.
• Hot/Cold Barrier – Helps keep the heat from the heat exchangers from ever hitting the cold air in the bag.
• Semi Ridged construction – The bag will keep its shape when empty.
• Shovel system allows you to store a shovel on the bag for quick use while not restricting entrance into the bag.
• Reflective strip along the back for added safety and visibility.
• Inside you’ll find a mesh zipper compartment on the bottom side of the lid and 2 mesh pouches on the sides for extra storage.
• 3 elastic straps are located in the bottom of the bag to keep your contents in place during your ride.
• 2 elastic loops to keep water or pop from bouncing around in the bag.
• Waterproof zipper with dual zipper pulls.
• Bag is universal and will fit most models.
• Attachment is accomplished using cam buckles which rivet to your tunnel.
• Full zipper so you have full access to all of your gear.
• Available in Black only!
• 4-6 plastic feet are sewn into the bottom of the bag to keep it off of your tunnel and prevent wear to the tunnel bag.
• 1 year limited warranty against manufacturers defects.
• Made in the U.S.A.
Bag Dimensions:
Mini - 12" x 12" x 7"
Max - 12" x 16" x 6.75"
This product was tested last season in some pretty extreme conditions. Phatty from the Boondockers crew used one as well as our own testing here in the Midwest. Snow conditions ranged from powder to spring wet snow.
During these tests we found the content of the bag stayed dry and NO condensation!
Questions? Fire away!!!!
http://www.sledsolutions.com/store/i...?cPath=165_224
Thanks for looking!
Paul
Problem solved....
![SSES2MAXOPEN.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/SSES2MAXOPEN.jpg)
![SSES2_WEB.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/SSES2_WEB.jpg)
![SSES2MAXOPENWEB.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/SSES2MAXOPENWEB.jpg)
![Bottom.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/Bottom.jpg)
![SSES1_WEB.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/SSES1_WEB.jpg)
![SSES1OPENWEB.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/SSES1OPENWEB.jpg)
Features:
Bag Dimensions:
![MunisingDay115.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/MunisingDay115.jpg)
![BagTestWET.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Product%20Pics/BagTestWET.jpg)
![PC050037.jpg](http://i481.photobucket.com/albums/rr172/SledSolutions/Riding%2010/PC050037.jpg)
Thanks for looking!
Paul
