C
The G4 turbo was way harder on gas than a NA. I expect the G5 turbo to be even harder on fuel.
You can really see the difference in the new track too.Another observation here with coolant flow in the tunnel. Will this new pattern cool quicker because it has less turns?
Pic 1 g4 165
Pic 2 g5 165
View attachment 395910View attachment 395911
Just swap out to stiffer rear torsion springs. Make a way better difference that playing with the rear shocks. There are several one availables.I rode a 165 saturday and purposly put myself in a ugly steep spot and just too much wheelie for my style, man I sure wish they offered a lock out for the rear shock from the bars for them ugly spots!!
Pic 1 g4 165
Pic 2 g5 165
They do it’s called the IQS by FoxI rode a 165 saturday and purposly put myself in a ugly steep spot and just too much wheelie for my style, man I sure wish they offered a lock out for the rear shock from the bars for them ugly spots!!
I'm impressed with the 2023 Expert's running boards. They do a great job of not holding snow.
In fact, it is set in the 1/5 position from the factory.You're wrong.
For 2023, per page 179 in the owner's manual, it's in the 4/6 setting, not 1/5 from the factory. Also, there's no way the adjustable limiter could move from 1 to 5 given its mechanical limitations.
I checked mine (2023 Summit Expert) and sure enough it is set at the 4/6 setting from the factory.
From the owner's manual:
Quick Adjust Stopper Strap System
On models equipped with an adjustable stopper strap, the lever posi- tion can be changed at any time. The crank mechanism will switch po- sition when tension on strap is released, i. e. when front portion of suspension is slightly compressed.
PRECISION+ to AGILE
From factory, the adjustable stopper strap is set in the way where the "AGILE" position = setting #4 on regular stopper strap. The "PRECI- SION+" position = setting #6 on the regular stopper strap.
The adjustable stopper strap length setting can be adjust by changing the bolts to the long position holes. Refer to the following illustration. Then, the "AGILE" position will = setting #2 and the "PRECISION+" position = setting #4.
Furthermore, you mentioned that the adjustable limiter could not move from 1 to 5 due to its mechanical limitations, but that is incorrect?. The lever position can be changed at any time by releasing the tension on the strap and allowing the crank mechanism to switch positions.?
They do….it’s called FOX IQS!?I rode a 165 saturday and purposly put myself in a ugly steep spot and just too much wheelie for my style, man I sure wish they offered a lock out for the rear shock from the bars for them ugly spots!!
How about get rid of the torsion springs all together. I put the Tom’s torsion spring delete on my 2022 Freeride 154” w/ Fox QS3 Evols! The BEST mod you can do to a Skidoo Summit…by far, hands down! Try it….you will never ride another Skidoo with those stupid outdated torsion springs!Just swap out to stiffer rear torsion springs. Make a way better difference that playing with the rear shocks. There are several one availables.
This is an old chart, but you can choose the rate you want, go down all the way:
All the race sleds with latest tech have torsion springs. How is this possible?!How about get rid of the torsion springs all together. I put the Tom’s torsion spring delete on my 2022 Freeride 154” w/ Fox QS3 Evols! The BEST mod you can do to a Skidoo Summit…by far, hands down! Try it….you will never ride another Skidoo with those stupid outdated torsion springs!
Exactly….race sleds. I’m talking Mountain sleds! If you don’t believe me….google Tom’s emotion delete kit.All the race sleds with latest tech have torsion springs. How is this possible?!
That’s some funny **** dude! You go ahead and keep thinking thatBecause some just don’t know, A good shock tuner can make the factory KYB’s superior to the aftermarket name brands.
