Tempest Goggles
OHHHH now I know where I've heard CKX before. Those helmets are seriously slick. I'd get the combo setup like your buddy does, but it's not in the budget right now... maybe next season. Maybe I should try to sell my Tempest goggles...
the tempest goggles arrived and i went with the infinity style in blue and a spare yellow lens. cost was 255.
they come in a nice box but i'll never use it since the goggles will live in the cloth sleeve like all goggles come with. i'd prefer they deduct the cost of the box from the price as an option.
the cloth sleeve does have an additional pocket to store a spare lens.
the goggle's foam seal is thicker and these fit on my 509 helmet no problem.
no battery pack hanging off which is great and only one button which when pressed, lights up the LED battery status gauge. lifting up on the tab that the battery status button is on exposes the charging port.
the pic of the clear lens is the internal, heated lens.
magnets attach the lenses and they are very strong as someone else also mentioned. that's a much better attachment method than the previous ABOMS. as the tempest rep told me, these goggles have been completely re-designed.
  • Like
Reactions: jh7
Is there really no way to turn them off? On days I use my heated goggles, I carry a spare pair. But If there's no way to turn them off, the battery on my spare pair would drain while in my pack or tunnel bag,
Yeah that's one of my main issues with them... they have no off switch. So you cannot charge them and leave them in the trailer; they will power up and run down before you ever leave for a ride. You have to have them inside and plugged in the day before. Major design oversight, IMO.
i'd just store them under conditions that won't cause them to turn on. cold or cool and dry or leave them outside.
i won't know till i use them but i can't see that being an issue and if it is, there's easy work arounds.
I've never had an issue with battery going down when not in use, in storage. I bring them inside like I do with the rest of my gear. Keep in mind, they don't just turn on because it's cold, the sensors need to detect moisture first.
Like I said, to me, it's never been an issue.
Weird... I remember charging mine up and then putting them in the handlebar bag on the sled in my trailer... came out the day before a ride and they were dead.
that's what i'm thinking. Rob brings up a good potential thing to watch out for but these have been out for over a year and i didn't see any reviews that mentioned that being a problem.
I absolutely loved the photochromatic lense I used today. Clarity and contrast were excellent. Top notch with the new 509 helmet.
I bought a set of the Tempest goggles this year too. I haven't tried them with my helmet yet, but after reading this thread I'm going to tonight. The fit against my face isn't great. I have a pretty wide, fat face and wear XL/XXL helmets depending on the brand. They seem like they would fit a narrower face shape much better. Would be nice if they indicated the fit style on their website.
Seems like there might be a little bit of distortion looking through the lenses. I tried to find a protective layer that needed peeled off, but I didn't find one. Might be a side effect of the coating that heats the lense?
According to the instructions included in the box, for the goggles to come on two conditions have to be met: 1.) temperature has to be low enough AND 2.) the humidity sensor has to sense a high enough level of humidity. It says right in there not to store your goggles in a damp gear bag or put them back in the case when they are damp because the humidity will get trapped and if cold they will turn on and run the battery out. You can store them in the cold IF it's dry. So leaving them in a trailer with wet gear and sleds probably won't work.
  • Like
Reactions: bfr
Follow up. Haven't ridden with them yet, but the fit seemed a little better on my face when paired with the helmet. Pressure applied pulling out on the straps flattening the frame a bit? However, now I can feel the wide, flat part of the frame inside from the face foam touches my face right by my eyebrows. I guess I'll give them a shot and if it's an annoyance while riding I'll try to offload them to one of my buddies and go back to my tried and true Smith.
got out yesterday and tried out the new tempest goggles and they exceeded expectations. goggles were continually fog free-there was never a time when fog appeared and then the goggles removed it like other heated goggles i've tried, any fogging never appeared in the first place.
worked as advertised and better than the original ABOMs and those were good.
Got my wife Tempest goggles for Christmas. She had her first ride with them today. It was cold, socked in, and snowy. Fog was 100% non-existent for her. I’m still rocking 509’s and fogged several times, particularly on the ride out. Riding the next 3 days in Revelstoke. So I might be ordering a set before this trip is done lol.
Wanted to put my experience. I am one with a big head and the fit wasn't great. I iced up on the inside and due to goggle fit, sensor never senses humidity so they stayed iced up. Called Tempest and more or less, not much can be done if goggle doesn't fit. Once worn you can't return it.
If you have a normal size head, I'd try Tempest, but if you are an xl helmet size, I'd stay away. Return policy is poor for a direct mail company.
What kind of helmet? I wear an XL in a 509 Altitute 2.0 and the goggles fit fine with no issues. Why would the fit affect the sensors ability to turn them on?
Klim f5. Googles don’t fit my face great when not in the helmet either
The Tempest have been fantastic for me this season. I'm getting 3-4 rides between charges, no fog and they fit well. We have 4 pairs of them in my group and we've all had the same results.
  • Like
Reactions: bfr
