Another good ride yesterday
Same aprox elevation as all other rides this year, as all I have done is local riding so far. This time we spent a good part of the day doing some tricky technical riding in trees and tight cut-lines, with the last 10 miles ditch banging back to the trucks.
I still see the small rpm loss, ran about 7400 or so all day. I also still think it is less responsive at lower rpm... but that is just a seat of the pants feel, so who knows. Overall it is still running great and I am keeping up with or passing the new sleds I ride with. I will probably swap cans back to the MBRP just to see if I get back my rpm and response.... considering cutting it apart to re-pack it.
I am also starting to notice just a little more off-throttle front end dive this year, I am thinking about stiffening the ski shocks up to match my stiffer rear suspension (225# front spring, and .375 torsions)
This is the cool part.... Near the end of the day we were in a spot where we could do some 0 - 70mph drags. Along side me there was:
09 RMK 800 155 (2010 update, slp single pipe set, Vforce reeds)
09 800 XP 154 (dropped from 21t top gear to a 19t)
08 Dragon 800 155 (2010 update and can)
The only sled up front with me was the lower geared 800 XP, we tagged back and forth for wins depending on the hole shot.... all other sleds were noticeably behind right out of the hole and continued to fall behind as we built speed.
Aside from the little quirks I am sorting out, I am quite pleased with how my 9 is performing.
*EDIT*
I found the source of my front end diving that I felt the other day lol, right lower A arm is broken around the sway bar pocket area, and the sway bar was out of place. I can see where it had been rubbing on the top of the A arm, so I definitely put on a few miles with the arm broken and spread apart a bit, and no sway bar. I'm off to the dealer 2 hours away tomorrow morning to get the arm and a few other goodies. I need to get it bolted together and ready tomorrow evening before I go back to work for my set of 4 dayshifts.... we ride on my first day off saturday
