A
ACMtnCat
It states 477lbs . . . where are you getting the 453 figure from? the 08's weigh pretty much the same as the 07's wich weigh 500lbs +/-
your just pulling number outa your a$$!
And let's not forget the extra 20lbs of snow weight gain according to snowest magazine.
AAAHHHHH!!!!
I knew that would confuse the Doo guys! Just because you have a M8 does not make it ok to spread the Doo propaganda of "quote dry weight" and incorrect data you read on Dootalk and BRP add untruths. Next youll try convincing me that your xp weighs 435# and has 157hp because you went up against a poorly set up M8 once last spring and highmarked his a$$!
The 477# is created weight. Meaning the sled and the create weighed that much as it was set on the diesel trailer.
That is not out of my a$$ there SNOWCATTER.
Pull the sled out of the create and it is 463-465# that has been documented by certifide freight, taking in account the boss seat would put it at 453-455#. If anyone that spring checked can prove that is not true, Cat will rebate $500.
Cat has produced a 800cc sled this year that will go head to head with the mighty XP stock for stock! Not to mention the supierior hanldeing the M chassis has over the XP in the steep mountain terrain!
Doo can keep the 16" wide track, the 15" will out perform it in so many other ways.
