NopeHave they said when you might see this trailer?
Have you thought about maybe doing a spread axle? Instead of going three axles?
Not familiar with the term?
Two axles, but you spread them apart a couple feet.
How do you turn?
With the steering wheel in your truck? J/K
it's really no different than turning with a tri-axle trailer. You get a bit more tire slide/drag then with a tandem axle especially on tight turns but the spread axle is said to ride better. You see it a lot in semi trailers as you can actually get more weight on the trailer as it spreads out the weight per axle if I remember correct (but the trailer has to be built for the extra weight)
I guess the better question would be how did the last trailer pull for you? Because your new one should be the same correct. If you were happy with the last one I would not change the new one. Just my opinion.
Trailer TOWED just fine.
Wouldn't mind having a Turbo Diesel to pull with rather than a V10 though.
And a long bed would always be better than a short bed.
I am holding out for the new 2016 F250 coming out next November.I bet if you hit up FORD, they'd build you one special just like Mirage is doing for your trailer...
