<<< SnoWest Arctic Cat FREE SLED Giveaway>>>
Status
Not open for further replies.
I agree with the 16 updates and something like a Snowest themed wrap.
Who doesn't want a free sled!?:face-icon-small-hap
Well if its an open wallet then.....
16' front end
Updated shocks
BB
Narrow boards/side panels
Some carbon fiber
SW custom wrap
Man what fun a free sled could be :-)
Keep it simple. Copy 16 LE with a light weight can, Ti, and TKI belt drive. That is all you will need. :face-icon-small-hap
Shoot! I just noticed that a forum member is going to win this sled......so I'm going to change my tune.
3" Powerclaw
Tss Rapid Response Turbo Kit
C3 Carbon Fiber Hood
Skinz Front end with Evol Shocks
P85 primary clutch and have a 2016 Team for backup.
Team Tied secondary.
TKI Belt Drive.
Skinz Freestyle seat.
CR Racing running boards with cooling capacity for the water to air intercooler.
Next Stage Gauges Reflash
Full K Mod suspension all the way around.
Carbon Fiber Vents
CFR Bars
OFT Turcotte kit
RSI Handwarmers
MoHawk Skis
Complete Titaium bolt kit
Rox Ghost Handguards
Hiperfax
Avid 7t drivers
Plus the winner should get all the stock take off parts with the sled just in case they need them or wish to sell them:face-icon-small-win
Or what he said.......:face-icon-small-hap
Project Vader or Project Black Knight.
definitely SLP set up and narrow it down, but whatever you do to it, it'll still look good sitting carving up the mountain.
Don't know if this has been suggested yet for the ultimate build, but pull the oil cap off and drive a new Pro RMK under it...:boink:jk
I started a 2016 and beyond thread last year about now, so let's just start with that list which cat has done a great job addressing already:
2016 clutches
2016 skis
Lose 25 lbs with belt drive and carbon fiber hood
See if Cat has an R&D Ctech 800 laying around somewhere...if not, Stage III the sucker
'16 front end
Evo shocks. That should about do it. Don't want to get greedy:face-icon-small-coo!
Personally it sounds like the new front end and rear suspension geometry sounds like it will make the sled overall handle better. That being said I'd like a focus to be on cutting weight. Carbon fiber, titanium, lightweight exhaust and the best venting available. Possibly oil delete as well to cut more weight.
http://www.snowest.com/2015/03/project-201516-arctic-cat-m8000#
Project 2015/16 Arctic Cat M8000 SnoPro Build Is Underway
Published online: Mar 23, 2015 Arctic Cat
Steve Janes
For those who aren’t followers of the SnoWest Forums, you may not be aware of a project sled giveaway that we are doing with Arctic Cat this season. So let me bring you up to speed.
About a month ago Arctic Cat corporate called and said they had an extra 2015 Arctic Cat M8000 SnoPro snowmobile that wasn’t assigned to anyone and wondered if SnoWest wanted to do anything with it—sort of like turn it into a project or something.
During that same period, we had been spending some time with Cat’s R&D staff riding the prototypes of the 2016 models. Naturally there were some significant changes to the ‘16s that we knew would be great additions to this ’15 project.
Using our connections, we managed to talk Cat out of a few parts (not yet available to consumers) and started working on our new project Cat.
Naturally, since we where building a hybrid snowmobile for next season, we needed to decide what the end purpose of the sled would be. It was determined that at the end of the build we would give the project Cat away to one lucky SnoWest Forum member. (The great news is that anyone can join the SnoWest Forums before next fall when the build is complete and we give it away.)
And the best part about the entire project is that we’re using comments from the forums to ultimately determine what goes on the project Cat … right down to the name and design. You can follow the thread here: http://www.snowest.com/forum/showthread.php?t=394235
Part 1—Front End
So the first thing we acquired for our 2015 Cat was the new front suspension. The handling between the ‘15s and ‘16s are like night and day. And everything starts with the new spindle design.
What you notice with the 2016 spindle’s sleek design is that the caster angle is changed from 17 degrees to 27 degrees. This change in geometry makes a world of difference when riding terrain. The spindle design takes away the sled’s tendency to climb when sidehilling and allows you to hold your line with a lot less effort.
The new geometry allows the sled to roll over on its side with a lot less effort. (This was really noticeable when working on the sled. After we put one side on and rolled it over to do the other you could tell immediately it takes more effort to roll the ’15 over the ’16.)
The shock angle and length is also a little different, which improves the handling in the bumps. But to make this project just a little nicer, rather than grabbing the standard Fox Float shocks, we snuck out a set of Fox Evol piggyback shocks for extreme performance riding. Installed, they will be a little more vertical than the old shock.
Finally, to finish the front we definitely wanted the 2016 skis. This year Cat has come out with some significant changes to make the skis perform better in powder.
First, the keel was increased from 1 inch to 1.5 inches in depth. It was also extended longer and built on more of a rocker style. To accommodate for the adjustability in ski stance, the sidewalls of the ski were extended out to the edge. The combination of a deeper keel and sidewalls allow the ski to work much better in powder snow with a greater turning surface. The skis were also widened in the front to 7 inches, tapering down to 6.5 inches (the old ski was only 6 inches wide).
We also added the Limited Edition bumper to this build, giving us great protection to the front end for tree riding.
Installation Process
1) Remove hood. There will be six torque screws to remove. Four are the same length and the two under the nose are longer.
2) Remove the black plastic skid cover under the nose, along with the aluminum skid cover, to expose access to the lower A-arms.
3) Remove the rubber boot that secures the lower A-arms. Pull the pins straight out (much like those that secure the windshield). This will allow the rubber boot to be pulled away, exposing the bolts that secure the A-arms.
4) Now that everything is exposed, remove the A-arms (four bolts), the upper shock bolt and tie rod. (You can break it down into parts, like taking off the skis, spindle, etc., but we were taking it all off at once. It’s also helpful to just loosen all the bolts first, then doing the final removals so you don’t have to fight with dangling parts.)
5) Reverse the process with the 2016 parts (you will need to use the some bushings, washers, bolts and ends you removed from the 2015). Things to note: the new A-arms will have either an L or R mark cast on the inside of the arm so you know which side they go on. The upper arms are identical so it doesn’t matter which side … just make certain the shorter length is to the rear. Also, do not completely install the rubber boot until the end so you can do your alignments.
6) Assemble shocks from existing attachment parts. Basically, whatever you strip off the stock shock you will be using for the new shocks. When installing the Evol shocks, make certain to put the piggyback chamber forward so it won’t rub the chassis. (Shock adjustments will come once we get on the snow.)
7) When installing the spindles, you’re going to find tightening the bottom shock bolt to be tricky. We go to the point where the bolt was spinning in the housing (while the sled was still on its side). We then let the weight of the sled fall on the bottom of the spindle, applied a little down-force pressure on the A-arm and finished tightening the bolt.
8) Install skis with spacers either inside, outside or both, depending on the width you desire.
9) Align skis with steering. You can install a properly sized-to-fit screwdriver or bolt into a hole on the front end that will lock the steering in a straight position. Then it’s just a matter of adjusting the tie rods to get ski alignment. You want one-eight inch tow-out on each ski. Once steering is aligned, lock set nuts in place.
10) Re-attach rubber boot by putting push-pins back in.
11) Before you re-attach your aluminum and plastic skid plates, install a clip that will be used to attach the black plastic skid plate.
12) Re-install aluminum skid plate.
13) Re-install black plastic skid plate.
14) Remove stock bumper if you chose to install the Limited Edition bumper to add a little more meat up front for tree riding.
We removed one side first and then installed the 2016 parts before moving to the other side. The kit (which will be available this fall and will fit all SnoPros from 2012-15) consists of the following: two upper arms, two lower arms, two tie rods and two shocks. (We also installed the 2016 skis … which are a huge improvement.)
The kit can be ordered for a 36-inch front end or for the Limited Edition, which comes in a 40-inch front end and Fox Evol piggyback shocks. (We went with the 36-inch front end but opted to install the Evol piggyback shocks … sort of a mixing of the regular and Limited Edition kit.)
We started with a 2015 Arctic Cat M8000 SnoPro. But before we’re done, it will be anything but a stock SnoPro. Give some thought to the final name and graphics of this project sled and let us know your ideas.
Acquiring the parts took a little sweet talking, some bribing and a little “midnight appropriation” but was well worth the effort. Good thing there weren’t metal detectors on the exit door.
But while “acquiring” parts, be sure to get the hardware needed. Most of this should come in the kit that Arctic Cat will offer. But our acquisition came prior to the availability of the kit.
We stripped the sled down by removing the hood, side panels and bottom skid plates.
You want to get everything exposed so you’re not fighting with anything. That includes the black rubber boot at the nose where the lower A-arms attach.
These are the parts that will come in the front-end kit, plus the necessary hardware. The Fox Evol shocks will actually come in the Limited Edition kit.
A lot of blood, sweat and swears (I mean tears) come into doing your own install. But the reward is always worth the blood you shed.
There is a trick to tightening the bottom shock bolt on the spindle (explained in the install).
You can really notice the increased camber angle on the new spindle in relationship to the old spindle.
For ski alignment, you want to have an eighth-inch tow-out on each side. Notice the unique tools we’re using to make certain things are accurate: first, the bolt in the nose of the sled to lock the steering in square position (we have a specially designed
Be sure to lock your jam nuts in place and then re-attach the rubber boot.
If you are going to install the Limited Edition bumper, be certain to add a clip to the nose piece prior to installing the skid plates.
Installation of the Limited Edition bumper is relatively straightforward. You have seven hex bolts. It’s best to get all bolts started before you snug things up.
2016 updates, clutches etc
3" powerclaw
single pipe and can
skinz airframes
BDX headlight delete/airbox
What I would do is put everything on it that Cat will let you get away with to make it into a 16 and to lighten it up. Then I would contact all of the aftermarket people and ask them if they would like to participate in the build and donate some of their best parts. They will probably even send out a tech to install their parts. Maybe when you have a list of companies willing to donate their parts let us vote on what parts we want on the sled. Personally I would be happy receiving the sled however it is finally put together. Snowest is the best place to look for advice on what to do to a Proclimb!! I hope Cat is also watching this build to know what to do in the future to keep their loyal customers!
"So, would you like a brand new 2016 Arctic Cat sled for FREE?" YYEEEEPPPPPP, I sure would
I would leave the stock oil injection on.
SLP Stage 2 or 3
Lighten it up
Upgrade suspension.
Custom color-powdercoating
But whatever you do to it, I wont complain when I win it.
I agree with lightening it up, perhaps a belt drive and new can.
Status
