07SummitX800R
Yes, I'm anxious to know also. Great photos.
We didn't get much time on it last season not a lot of the white stuff here last year....
It pulls off the bottom better, the belt is all the way to the bottom of the Primary & all the way to the top of the secondary.
Lighting up the shoes on the centrifugal clutch just lets the engine get a little head start before the track starts to turn.
The top end is a lot better than stock, next to a "stock Scoot" it will out run it no problem, never had a chance to get along side with a big sled to get a speed reading, I would say maybe 40 mph?
We cut & ground as much as we could so I think it is at it's limit now..... We will know better in a few weeks if the weather keeps going the way it is now.
Did you do some additional holes in the shoe ? ,you have a pic after the shoes was lightning ?
Thanks for input
Interesting stuff. I have a scoot and a sport. Been playing with clutching on the scoot as we've been overloading it with me and all the kids climbing on it at once! Now looking to long track the sport (108).
Anyway, I've replaced the scoot secondary spring with a new sport spring and shimmed it so the scoot wont die under heavy load. But disengagement is a problem. Was just going to try heavier carrier springs (already have sport springs there too) but lightening is a better idea that I didn't think of... Might drill though. Anyway, I'll see if that does the trick!
Did you check the rollers in the Primary? They tend to get flat sided & gummed up from the grease that was put in at the factory, we will check the rollers, replace if flat sided & clean out all the grease & crud. We put back dry & they have been good so far. Might help your disengagement problem.......
Has anyone looked into the DR. Pulley Clutch kits. They can come with different springs etc for tuning?They are for the scooters as their is tons of aftermarket hop up parts for these things on the scooter side.
