as far as why it works at higher elevations is simple fuel curve physics. you need less fuel at higher altitudes. so if the m8's are fatter on the parameters accross the board, the higher you go with the sled, the less fuel you need, the more cushion you have. as you drop lower to the 0-3000 elevations you are making more power, and even though the parameter might be fatter, you still might not have enough cushion to run safely without a controler from what slp states.
i still dont have enough info to talk myself into running this without a box. but as yooper has said, the cost for what you get is slowing the purchase. i am really leaning (no pun intended) toward just running it stock, +14 hp and -8 pounds or not. 550 for the pipe, then the air intake, then the fuel box or regulator your getting close to the 1000 mark, and i still wont know if it makes power or is safe at 0-3000.
maybe i should just pay the 495 to rk tek and get his 15+ hp power upgrade. want reliable, safe, and EASY power gain. dont want to be dickin with a fuel box all day every day to get the thing to run.
please for everyones sake, lets keep this about the m8's only. please start another thread for the 1000 then, we all know what each other is talking about. ski
