SLP performance edition kit. 09 M8 vs 10-11
iluv2fly
This is from dustin at SLP
The 2010-2011 kit will pull the 2009 kit by about 1-2 sled lengths. The biggest difference is in the midrange. The 2010 has a significant amount more torque and power through the middle of the power curve. On top, they are close.... but if you race the two up a hill, the 2010 comes out much harder and puts an easy sled length on the 09 right off the bat, then continues to pull over the 09 for a while until they start to even out and stay about two sled lengths apart. The 2010 defiantly has better throttle response and the engine spools a bit quicker than the 09. Some of this is probably due to the lighter crank. We are also using the PCV on the new ones which gives a few more options than the PCIII. We can program a start up mode to make the sled start easier...kind of like a choke.
As far as the reeds, they do help some...about 2-3 hp gain, but I don't know that you will feel it seat of the pants but they do help with throttle response. Keep in mind that the PCIII map was written with them installed so the mapping will be a bit more accurate when using the reeds, but I don’t' think they are something you absolutely need in this particular case. We have found that in most case the V-Force reeds make more power than the Boysen. We did not test the two back-to-back on the 09 with the kit, but I have been happy with the V-Force on this kit.
Hope this helps...feel free to post this if you like.
Dustin
I can't wait to here how this kit performs on the snow!
It is nice to know that these 800 H.O motors have even more potential!
John
Wow, that is almost word for word what Dustin told me.
It's the answer to the question from those of us with the 09 Performance Editon Kit. The question comes when we read the 2010 version of the Performance Edition Kit leaves one speechless! After all it hurts a little, because prior to the 2010 version of this kit our beloved 09s (with this kit) were the darlings of the SLP test mules. Now, we are just chopped liver. :rain:
Anybody over heard of using a nitrous shot on M8s? :D
