sled wont go anywhere?
It has been sitting for 4 years its a 2000 yam sx600r It only has 1100 miles on it. Starts sounds good feels like it wants to move at about 4grand but it wontmove even at high rpm.
Its been sitting for 4 years. Clean the clutches. Grease the bearings. Put new oil in the chain case. Empty the gas tank and bleed the carbs. Put new fuel in. Put the back end up and see if the track will turn.
Track stuck to the slides? Have you lifted the back end or rolled it on its side and tried to move the track by hand? can you roll the track by hand?
5000 engagement on a 600 tripple is pretty normal. Have you just pinned it for a couple seconds and what happens? You may have some weights stuck in the primary are a bushing somewhere sticking.
sled
Got it going thanks to all cleaned and flexed and moved all the parts some lubed some **** and put it together. Seems to go now just need to be ran some. Thanks again
The only lube you should put anywhere on a primary is dry powder graphite in the weight and roller bushing's
Liquid lube is a bad idea, if it was lubed in the past that may be why it is stuck now
If you pull the cover and remove the spring you can slide the moveable back and forth
