Hey 2 mx3 what ignition stuff u gonna run?? Where do u get it? Thanks
Is it possible that some of these sleds are running a bit rich on the bottom end and possibly causing them to detonate at low rpm? I know it sounds backwards, but it sounds like a few cases of det at low rpm or trail running. I would think the factory timing map would have advanced timiing at low rpm so maybe that is partially the cause. i don't know much about efi, but there has to be something causing it.We are out in Cooke City riding. Sled has run good for 3 days straight now. Ran good most of the day today, towards the end of the day my buddy took the sled for a rip, ran fine, I fired it back up to head in: now the sled is only running on 1 cylinder. Couple strange things: when I 1st started it up after my buddy rode it there was a wierd metal rattling sound and wasn't running right.(there was a chunk of stick in the by the primary clutch, I thought this was the issue, but wasn't) I shut it down and started it up and the rattling went away eventually, but its only running on 1 cyl. We changed the plugs, no change. We towed the sled in.
what we have done:
-We have tested spark, it has good spark on both cylinders. The MAG side isn't running though. We pulled plug wires to test, the sled runs when we pull the mag side(terrible still obviously), when we pull the PTO side the sled won't start. that's how we came to the conclusion the mag side isn't running. The MAG side piston is also wet like its not running.
We did a compression test, both cylinders are at exactly 90psi,that seems low, but we are also sitting at 7600ft elevation too. But they are both the same.
-We looked at the pistons and rings through the spark plug hole and VES openings and they look normal.
-The sled barely runs, it doesn't clear out if I try revving it up. It won't rev over 5500rpms.
No check engine light.
Sorry for the long post.
Any ideas?
Reeds were intact.If you can verify the broken bottom of the case, check your reeds or look for anything foreign object related..
Still considering my optionsIf u do have to rebuild, hopefully u don't. Would u go with Polaris oem pistons? Or would u try one of the fix kits? Any opinions on wut is best for the turboed sleds? Thanks.
I was not too lean, well at least going by my wideband a/f gauge and also by looking at the plugs and the tops of the pistons. a/f was at 11.5ish at WOT, it seemed somewhat rich down low and midrange. Would being too lean cause the piston skirt to break off, yet the tops of piston and rings be ok?X2 plus follow Justins instructions. Maybe you where too lean, according to this thread http://www.snowestonline.com/forum/showthread.php?t=290723&highlight=turbomatt
On topic, when I read someone using the bpr9eix plug I feel like I was told to run the br9eix. Any issues here. My sleds 2 hours from me so I can't check what I bought. Whats the proper plug?
SLP has the plug wires listed, I almost ordered them today.
Matt, having done quite a few D8 motors this is actually Not where they break, all the d8's break the cylinder skirt and piston skirt off on the EXHAUST side on the motor (ie thrust side), and from your picture it looks as if the exhaust side did not break. Hard to tell until you get it all apart. There is little load on the non thrust side of the piston skirt in the area where the break is in the picture so i'm very interested as to what you find in the rest of the engine when you take it apart. look for scuffing on the intake side,and for perhaps another broken section from the exhaust side that caused the intake side to break off by flinging about in there.
I have not seen or heard of a cfi4 D8 motor breaking a intake side skirt off,but of course many on the exhaust side. Keep us posted.
7 in green mode that is high. I think I run mine at 2 and bump up when to 3.5 on the trail.But I run high elevation so that may account for some difference.
Det. took out a skirt on my 06 900 that was bad fuel I think but DET is the same regaurdless that why I ask.
The 05 were famos for broken skirts but not the 06 so I was surprised when it happened.
I was riding at 9000ft elevation.
My sled has proven to do strange things. It definately made a huge difference running the GREEN mode at 7, both in throttle response(bogs) and on the wideband gauge. I was having the whole idle issue to start with as well. That seemed to be resolved, albiet still weird.
On another note 2MX3: I checked my throttle plate opening when I had my junk apart last night. You had stated that I should be in the .0025" - .004" range at idle. Even though My idle is fine now after turning it down manually, my throttle plate opening is still at probably around .007". Strange, i'd bet it was over .020" before I turned it down(this is how it was set with my TPS adjusting tool). I wonder if there is something up with my TPS?
