H
Hairy Mark
i know this would be a pain in the butt, but have you tried swapping boxes. that might answer several questions.
I would agree with this, rode quite a bit yesterday at 5500-7200 ft, 8-9 lbs,100%av gas,80 grams.
I would not run a motor under boost at leaner that 12.5 -12.7 imho
Still messing with the box and installing a much more accurate boost guage today as I dont put a lot of faith in the included boost guage, new one im going to is a vdo 0-15 psi full 270 deg sweep, much more stable and easy to read small changes. I would reccomend this, its 50 bucks from summit,same size btw.
sled pulls very hard climbing....![]()
Every time you restart the sled it calibrates itself to the atmospheric condition's. That is why the solenoid is there.
IMO what is causing this det light to come on around the 6500 rpm mark is a lean spot. I had my sled out yesterday and it ran great. i was at aprox 4000 feet and ran 7 psi to start than ran 9 for a while On straight av. As soon as i tried to lower the yellow blue i tripped the det. i was told by a couple guys to lower it at altitude so i tried it...
green to 1 from 3
yellow 3 from 4
yellow blue to 2.5 from 4
As soon as i changed the yellow modes i hit det! What i started at for settings in the box and left it like that for the day with no det light issue was.
Green 3
yellow4
yellow blue 4
g/b 3.5
red 4
red blue 4.5
My a/f was between 11.9 and 12.2 at wot on a long pull that i repeated several times. I pulled the plugs and they were a nice tan brown, i would not want to go leaner. So the guys that say they run 12.8 or 13 af might be full of sh**. Same guys that say there running 74 gram weights @ 12 psi at the same altitude when im running 79 grams at 8 psi.,.. Get your sled out in a place where you can sit and watch the modes and what throttle position your at and where it goes lean. I know im still learning my sled. Although the bottom end on my pro was clean, top looked like it could pull along side a mcx nytro that runs very well that was there running 16 17 psi. We never raced but watching them run it would be along with it.
l
umm if voltage is in fact on the edge i'm wondering if the good ol headlight delete would be a good thing, dropping 2 bulbs from the system?
Along with this perhaps a small battery such as the yuassa #7 from the wr450 dirt bike to stabilize the voltage?
Right. But thats why justin put the solenoid there! So you you dont have to stop amd teboot the box .Its a great idea and worked great except the one time. That af gauge may draw alot of amps effecting it along with other things on. On i phone hard to type with big fingers lol
If conserving wattage is a concern, I'd install a switch for the headlights. I'd never want to ride a sled with no headlight available for low visibility or night time use.
With all dobeck type boxes you will have to stop and let the box recalibrate for altitude on the way down. You will see green/blue at idle and runs rich when this happens.
When you stop the solenoid is not powered up to close. And the box will see actual altitude pressure. Then when you start up the solenoid closes and box will see any boost pressure. I ride from 3000'-8000' and usually have to do this once on the way back down.
