The outer diameter does change a little (~+0.75") on a typical larger diameter wheel with a lower profile tire. If you felt any deceleration effect it was due to the diameter change and its effect on reflected inertia to the motor and the torque change. Not the minor change in inertia of the wheel. 3/4 inch dia. change on the tire will add about 250 lbs to the reflected inertia on a 5000 lbs truck, about the same as adding an additional passenger! Thats what science and math does, points you in the right direction and away from the snake oil! I'm out of here, good luck and I hope you enjoy living in a fairy tail land where the sky is pretty shade of purple.
Cinno.
Since you're argument about weight is invalid, now your flip flopping to diameter as the reason?
You're an idiot, thanks for proving my point!
Cinno,
Ur calculations are correct, ur math is wrong.
20% weight reduction on the track has a huge impact on track acceleration!
Snowmobile tracks will always accelerate faster than the sled.
The amount of snow the track can grab will always weigh less than the sled, therefore the track (path of least resistance) will push the lighter load (snow) rearward at a much faster rate than moving the heavier load (sled) forward.
The load on the track varies so much due to sled angles, speed, and snow conditions, not to mention track length, lug height and design, extremely difficult to quantify
GS6
You did not say anything specific about weight in your first example! But lets assume a typical weight change of +15 lbs for increasing to 20" dia wheel. That 4x15 or 60 lbs increase in total weight for the wheels. Which is greater 60 or 250. In other words the inertia effects due to a slight diameter change and gear ratio change is ~four times greater than the simple weight change of the wheel. I'm making assumptions about weight and diameter changes to help you understand how one effects the other. If you felt something by adding 20" wheel it had to be the ratio change as you would not feel 60 lbs change. But maybe you can?
As far as the idiot comment, that typical behavior for a little baby when you take away his popsicle.
Cinno
You still can't leave the diameter out of it can you.
Well I give up trying to solve this problem, as you didn't describe any relevant details. wheel weight change, tire diameter change , tire weight change, wheel and tire width change, tire pressure change, air temp, air density, altitude, and how many people in the cab. Nothing.
i guess it was a trick question to bait me into making assumptions. You win.
Cinno
I dunno....Caveman push throttle, make sled go up hill.
Here is some easy reading about how to size motors in applications that require extreme accelerations and how important gearing is to proper motor sizing.
The second article consolidates many of the equations necessary. Its called a "cheat sheet". The fourth page has some examples of drive train configurations that show how torque, speed, and reflected inertia (J) is calculated for those different configurations.
http://machinedesign.com/archive/new-rules-sizing-servos
https://www.servo2go.com/support/files/Smart Motion Cheat Sheet Rev3.pdf
I worked in the motion control industry for 37 years before retiring (so I could enjoy snowmobiling more). When building a machine that cost several million dollars, the powers that be, do not give you a second chance when designing the system (computers, drives, gearboxes and motors ). They want it done right the first time or your history. So you use MATH. No touchy feely stuff here and no dynos. The computers and sensors inherent to these systems can tell you everything you need to know about why you screwed up.
Here is the order I spend my money on for performance mods (not a complete list) that all make a noticeable difference :
1. Clutch kit - increases efficiency that is tuned for your application (mountain, trail, etc)
2. Motor power mods - canister, pipe, .....
3. Traction - lugs, length, pitch, ......
4. Suspension - width,shocks, coupling
5. Sled overall weight - get a polaris and just weight for the next model.
6. A lot of money see burandt sled for sale.
1000. Rotating mass
Cinno
1000. Rotating mass
Cinno
Just wow........
Translation;
If you can't blind them with brilliance baffle them with bul*****.
You succeeded in discrediting yourself.........
Nothing more.........
The primary reason for the 'power loss' running 20" wheels on ur truck Has to do with sectional width. 99.999% of 20in wheels are wider than stock 16in wheels.
The low profile (to maintain similar diameter)also creates a flatter surface. The road contact surface area is probably doubled. Rolling resistance from twice as much tire contacting the road is the power killer.
GS6
Wheres the "brilliance" wheres the "bull****" , how did i discredit myself? Be a little more specific if you can. If you don't understand the articles then just let it go....
Cinno
I can't count the number of times that an incoming engineer would argue us that "this (x project) is going to work 100% because it works on paper", having it verified and approved for manufacture by several other consulting groups and overhead engineers, only to have it fail because they used assumptions and averages to make the formulas work well and didn't take into account the outlying data points that actually happen in practical application.
You can't just "assume" and "average" the numbers in a given formula and then expect it to work in all applications in the real world.
You can't take electrical engineering theories that come with building and tuning drives, PLCs, motors, gearboxes with minimal variability and directly apply everything over to mechanicals. If that's how you want to build your sled, that's your choice. It's obvious most of us will be going a different route.
As I'm only 3 years into my industrial engineering and manufacturing career coming from a previous career as a diesel performance mechanic and welder/fabricator I've played this game before. Although I agree with you in that math is the tool to take you most of the way there, you only get there 100% of the way if there are no assumptions in your model. The formulas and theories you've presented thus far have SOME merit, however, there are too many assumptions in them to make them fully applicable and correct in the real world (track slippage on the snow being a BIG one, using a set gear ratio on the tq curve vs. the variable values a CVT clutch allows us to have being another). I can't count the number of times that an incoming engineer would argue us that "this (x project) is going to work 100% because it works on paper", having it verified and approved for manufacture by several other consulting groups and overhead engineers, only to have it fail because they used assumptions and averages to make the formulas work well and didn't take into account the outlying data points that actually happen in practical application.
I don't understand your distaste for a dyno and why you would consider such a tool to be "touchy feely"....a dyno would be the perfect tool that has been, shall I say, ENGINEERED to test these theories and their practical applications. That's the exact purpose of a dyno; to be able to adjust the different variables on the same piece of equipment and test to see if what the math tells you should happen is what actually happens in real life!!! You can't just "assume" and "average" the numbers in a given formula and then expect it to work in all applications in the real world. A dyno's full application is not supposed to be to measure how much horsepower and torque one engine has in comparison to another and get bragging rights, although it's what we usually use them for. Again there are many variables from one engine to another, from one vehicle to another, from one dyno and one day to another, that make the results mostly moot in close application. Dynamometers were developed to be able to take the same engine/vehicle, change one variable...say, a snowmobile and changing out ONLY the track, and seeing what the change in the HP/Tq curves are. That's also why there are engine only dynos, transmission only dynos, and full vehicle dynos.....to get rid of the variables and see how the change effects the unit in question.....not to just use math and take an average or assumption and apply it to the whole.
By purchasing a polaris you are getting a industry leading low inertia sled, at over 100-300 dollars per pound it's just cheaper to wait until next years sled, which is usually lighter at a very competitive price. Ditch the suitcase, add a pipe, get a track length that matches your weight, don't worry or spend money on the little things as polaris does that for you.I will ....YOU SOUND LIKE AN IDIOT!! QUIT WHILE YOUR STILL BEHIND !!!
Not that you yourself is an idiot but your posts have gotten a little on the Mo Ron level and usually you have good reason but man that last post looks like drunk typing !!!!" Buy a Polaris and weight on the next model" ... Does that make the least bit of sense to the original post of rotational weight reduction ??????
