Raptor Khaos Conversion Kit
Hey I just put my Raptor conversion kit onto my 19 Pro Rmk 850 tonight. I went with the Eyelet, Longer limiter strap and Rail tip Anti stab kit. I was wondering if anyone had alot of trouble getting the skid back in once you had the conversion kit installed.. It went into the track without an issue but lining up the skid bolts was ridiculous. Also wondering if I have my limiter strap in the right position for the Khaos setting?
The limiter strap is TIGHT! With the sled tipped over you can only get a bit of slack in between the anti stab and front of the track.
Thanks
Sent from my CLT-L04 using Tapatalk
Did you not loosen the track tension bolts?
Thanks
Mine went right in. Yes, the rear axle has to be loose and tension bolts all the way loose. I always start the front arm bolts first and then the rear arm. IF needed a ratchet strap will get you lined up.
Thanks man, Im pretty sure your the guy with the video on YouTube on how to install this? I was going off of what you were doing and yours did go in easy from the looks of it so I was likely just fighting the tension from the rear wheels still being set how they were from before the kit was installed.
