O No Problem.
Another brain fart here.
How do you tell if you have a crank seal going out? Spray a little starting fluid around the seal, because it is sucking in right? Now on a turbo sled, when under boost this would be an opposite situation. The crank case when under boost is going to be positive pressure. So lets say you run 10psi max boost, so the minimum amount of pressure in the case is going to be 10psi, then it is going to increase as the piston starts down until the piston passes the intake ports. So a wild guess will say maybe 20psi max pressure inside the case, This is what we are relying on to lubricate the water pump/oil pump shaft. But when your at an idle, or at a no boost level, your actually sucking on the line. So after a nice hard pull, you back out of the throttle and you have it sucking the oil/gas back out of the line. Right?
Here is another thought, (stealing from the skidoo race sleds back in the day) they ran a piece of poly tubing from this cavity up and back by the steering post. You filled it with two stroke oil, and put a cap in the line (with a small vent of course) This flooded the cavity and gave you a visual of how much oil is in the area. Once filled it hardly ever needed much attention. But you could see it for sure.
Again good discussion. Really makes you think about the differences between a normally aspirated sled and a boosted sled.
This added boost pressure in the case is probably why a crank seal wouldn't necessarily cause a lean burn down, the boost controller would just open up a bit more to maintain the set pressure. But you would start to see oil/gas blowing out on the back of your clutch or inside the recoil housing. And you might have a high idle because without the boost your sucking air again.
Thunder
Good info here.
The one way valve is supposed to only let the crank case pressure flow one way, towards the center section. Right ?
