7
715sledUP
I add oil to fuel on every tank. Never lost a premix engine so why stop now?
What ratio do you run?
how would one do this?There is an oil ratio map in the ECU that can be turned up
this method is viable for the '18-'19 motor as mentioned previously. However, on the '20-'21 motor, fuel is injected into the transfer ports and never gets into the lower half of the crankcase. Therefore, adding oil to the fuel of a '20-'21 has no benefit.Any issue with putting a couple ounces of oil in the tank when you fill up with fuel?
