Brycter does it matter if you have the map sensor on the pressure side on a 2t application? I know in 4t world you want it on the vacuumside (behind throttlebodies).
Why i ask is if i should go with a map with built in temp sensor(intake side) or just go with a map only sensor so i can plug that into my vacuumstation.
Also do you have a map laying around for a 2863 turbo that i can use as base?
Can go either 10,2:1 or 12,5:1 compression ratio. Got rktek domes that i can change between.
Sensors im using:
Wideband lambda, Map/mat(+ oeam map/mat for baro), Fuel pressure & electronic boost solenoid.
Other info:
670cc Bosch ev14 injectors, Aeromotive 13301 Fuel pressure Reg, Vforce 3r Reeds.
Cheers!
Sensors im using:
Other info:
Cheers!
