Did you change anything else or just drop to lower hole?I dropped to the lower hole on a 22' 650 Maytrix Pro. WAAAAY BETER!
if u haven't already, read post above/before urs.I'm working on converting my 165 Boost to Khaos, I have 22' Khaos shocks coming (now finding out they are likely the same length, but I did want the high and low compression adjustment anyway). I also ordered a Khaos limiter strap from Polaris, in doing this I noticed two part numbers, 1 for a 2.75" track and another for the 3' track. I want to ride it with the different limiter and shocks before making the decision on Rails. The limiter for the 2.75" was out of stock so I took the gamble on the 3" limiter being the same length and order it.
Does anyone with more access to part numbers and lengths know what if anything is the difference between the Khaos 2.75 and 3" limiter?
Do you know the difference in rear springs between the pro and khaos velocity shocks?When you add the Khaos limiter to the 2.75 PRO rails, you need the wider plastic bearing on the lower shaft or the limiter rubs the anti stab wheel.
The 2.75 limiter is narrower.
Coming from the racecar world, Preload is a good thing (there is an upper limit but it's a ways out). Every time we did shock tuning and made any weight adjustments King wanted preload in the springs to the point if the spring stack was too long for the shock they really didn't mind much.Pro is 210
Khaos is 185 but measures the same as the 190 spring.
Problem with the Velocity shocks, there is preload added just to install the keeper. I think we need a shorter spring.
Snow Fever, any other hot setup tips for the 650 Pro? Just ordered one for next season, looking for any insight anyone may have ?
This is true for Axys rails or old style driver matryx sleds without anti stab wheels. but not matryx rails with anti stab..Yes And the mount location is longer on the rails, hence the 1/2" longer eyelet in the kit or a 1/2" longer shock
Read posts above.So- does the longer shock or shock extension actually matter when you’re doing a longer limiter strap? What effect does it have when you’re riding?
The chart I posted was from the factory service manual. Do you have a pic of the 2022 Khaos velocity shock next to the 2022 Pro velocity shock? It’s hard to trust online info when it contradicts the service manual.Read posts above.
The chart you posted is not accurate.
I can verify that the velocity pro shock and velocity Khaos shocks are the same length.
*if you have velocity shocks and factory anti stab wheels simply swap the limiter strap…….
